Zyxel PLA4225 500 Mbps Powerline 4-Port Gigabit Switch
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 81MYWS00 Mfr#: PLA4225-GB0101F
Powered by the IEEE 1901 technology and four Gigabit Ethernet ports, the ZyXEL PLA4225 500 Mbps powerline 4-port gigabit switch provides an all-in-one solution for users looking to enjoy multiple HD streams, multiplayer gaming and web surfing simultaneously. When used alongside a powerline Ethernet adapter, the PLA4225 makes it simple to connect up to four media devices such as HDTVs, Blu-ray players, DVRs, and game consoles to your home network through any electrical outlet in your house.
  • Blazing speed lives up your multimedia streams
  • QoS enhances media streaming quality
    Advanced Quality of Service (QoS) features improve the quality of streaming multimedia applications such as triple-play services, HD video streaming, high-speed Internet access and VoIP.
  • Green technology saves energy
    The PLA4225 automatically enters power-saving mode when an inactive Ethernet connection is detected, reducing energy consumption by 80% when compared to powerline adapters without this function.
  • Easy security setup
    Data transmission is protected by 128-bit Advanced Encryption Security (AES) to ensure a secure connection to the Internet. There's no complicated setup or software required - the PLA4225 makes network security as simple as pushing a button.
Zyxel PLA4225 - powerline adapter - wall-pluggable
Powerline adapter - 4-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS)
HomePlug AV, IEEE 1901
7.6 cm x 7.2 cm x 10.8 cm
160 g
Microsoft Windows Vista / XP / 7
United Kingdom
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
HomePlug AV, IEEE 1901, FCC, RoHS
Status Indicators
Power, link/activity
4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
Internal power supply
5 Watt
1 x network cable
United Kingdom
7.6 cm
7.2 cm
10.8 cm
160 g
20 - 90% (non-condensing)
