Zyxel PLA4215 500 Mbps Powerline Pass-Thru Gigabit Adapter
500MBPS POWERLINE, WITH GIGABIT ETHERNET !
Quicklinx: 81MWWS00 Mfr#: PLA4215-GB0101F
Powered by the latest IEEE 1901 technology and a Gigabit Ethernet port, the ZyXEL PLA4215, 500 Mbps powerline pass-thru Gigabit Ethernet adapter, provides a stable, high-performance network for users to enjoy multiple HD streaming, multiplayer gaming and Web surfing simultaneously. With a pair of Plug and Play installed PLA4215, you can easily extend home networks through any electrical outlet for Internet access with HDTVs, Blu-ray players, DVRs, PCs and game consoles. The embedded noise filter enables the PLA4215 to suppress noise from all electronic equipment plugged into it and enhance the network environment for multimedia streaming.
Data transmission is protected by 128-bit Advanced Encryption Security (AES) security to provide a secure connection to the Internet. As a simple button press on both PLA4215 is all it takes to configure the encryption feature, there's no need for complicated setup or extra software.
  • Enjoy stable HD video and gaming
  • QoS enhances media streaming quality
    The advanced QoS features on the PLA4215 improve the quality of multimedia streaming applications such as Triple Play services, HD video streaming, high-speed Internet access and VoIP.
  • Green product saves energy consumption
    When there is no Ethernet link, the PLA4215 will enter a power-saving mode to reduce energy consumption by over 80% comparing to adapters without this function.
  • Easy security setup
Zyxel PLA4215 - powerline adapter - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS), integrated power socket
HomePlug AV, IEEE 1901
6.7 cm x 7.3 cm x 12.7 cm
235 g
Microsoft Windows Vista / XP / 7
Hong Kong, Cyprus, United Kingdom
Powerline adapter
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
HomePlug AV, IEEE 1901, FCC, RoHS
Status Indicators
Power, link/activity
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV - power BS 1363
Internal power supply
5 Watt
1 x network cable
6.7 cm
7.3 cm
12.7 cm
235 g
20 - 95% (non-condensing)
