Zyxel PLA4201 v2 500 Mbps Mini Powerline Ethernet Adapter
Quicklinx: 8Y7GWS00 Mfr#: PLA4201V2-GB0101F
Upgrade Your Home Network for Data Streaming with No New Wires!
The ZyXEL PLA4201 v2 500 Mbps Mini Powerline Ethernet Adapter can improve network performance by up to 60% comparing with 200 Mbps powerline technology** for stable HD media streaming. Just plug a pair of PLA4201 v2 into electric outlets, connect your router to one of the pair and any network device to the other to immediately enjoy HD media streaming, multiplayer gaming and other network applications simultaneously in any room.
Plug-and-play, compact design for easy setup
ZyXEL's stylish mini-size PLA4201 v2 gives you the installation flexibility to turn home electric lines into a network without blocking power outlets. The PLA4201 v2 features plug-and-play installation and upward-facing ports for easy, effortless installation. Add two or more units to easily extend your home network to enable Internet access from HDTVs, Blu-ray™ players, DVRs, PCs and game consoles.
Enjoy stable HD videos and gaming
Powered by the IEEE 1901 technology, the ZyXEL PLA4201 v2 provides a stable high-performance network to take full advantage of all entertainments the Internet has to offer.
QoS-enhanced media streaming quality
The advanced Quality of Service (QoS) feature improves the quality of multimedia streaming applications such as triple-play services by traffic prioritizing, HD video streaming, high-speed Internet access and VoIP.
  • The theoretical maximum channel data transfer rate is derived from IEEE 1901 specifications. Actual data transfer rate will vary from network environment including: distance, network traffic, noise on electrical wires, quality of electrical installation and other adverse conditions.
    ** Average throughput gain in typical homes
  • Plug-and-Play, compact design for easy setup
    ZyXEL's stylish mini-size PLA4201 v2 gives you the installation flexibility to turn home electric lines into a network without blocking power outlets. The PLA4201 v2 features Plug-and-Play installation and upward-facing ports for easy, effortless installation. Add two or more units to easily extend your home network to enable Internet access from HDTVs, Blu-ray players, DVRs, PCs and game consoles.
  • Enjoy stable HD videos and gaming
  • QoS-enhanced media streaming quality
Zyxel PLA4201 v2 - powerline adapter - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV), IEEE 1901
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Quality of Service (QoS), reset button
HomePlug AV, IEEE 1901
AC 220 V (50/60 Hz)
5 cm x 2.5 cm x 7 cm
77 g
Microsoft Windows Vista / XP / 7
United Kingdom
Powerline adapter
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
HomePlug AV, IEEE 1901, FCC, LVD
Status Indicators
Power, link/activity
1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV - power BS 1363
Internal power supply
AC 220 V (50/60 Hz)
4 Watt
1 x network cable
United Kingdom
5 cm
2.5 cm
7 cm
77 g
10 - 90% (non-condensing)
