ZyXEL's P-660R Compact Series is the next generation of compact routers capable of speeds up to 12Mbps (ADSL2) and 24 Mbps (ADSL2+). Enabling high-speed Internet connections, the P-660R is designed for small office, home office, and residential users. Enjoy ADSL services and broadband multimedia applications such as interactive gaming, video streaming, and real-time audio easier and faster than ever before.
Higher-speed Internet Access
ZyXEL's P-660R Compact series router complies with ADSL worldwide standards. With speeds of up to 12Mbps (ADSL2) or 24Mbps (ADSL2+), the P-660R series offers higher data transfer rates and better bandwidth than traditional ADSL enabled gateways. Users can enjoy not only high-speed ADSL services, but also broadband multimedia applications such as interactive gaming, video streaming, and real-time audio.
UPnP Support
The P-660R series supports UPnP discovery and UPnP NAT traversal. Using the standard TCP/IP protocol, the P-660R Compact series can join a network, obtain an IP address, convey its capabilities, and learn about other devices on the network.
Zero Configuration Support
Thanks to ZyXEL's exclusive Zero Configuration technology, quick and easy installation allows users to setup a DSL connection in minutes.
Compact Size (Postable)
The P-660R compact series benefits from its smaller size. It's compact, flexible, easy to install and cooler in both operations and appearance. Certain versions allow the router to be postable which is ideal for ISP's.
- Zyxel Prestige 660R-D1 - router - DSL modem - desktop
- Router - DSL modem
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+, READSL
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- Permanent virtual circuits (PVC): 8
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, PPPoA, AAL5, ARP
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, static IP routing
- Remote Management Protocol
- SNMP, Telnet, HTTP
- DHCP support, NAT support, ARP support, auto-uplink (auto MDI/MDI-X), packet filtering, dynamic DNS server, MAC address filtering, VPN passthrough, Zero Configuration Technology, MAP
- IEEE 802.1D, IEEE 802.1Q, UPnP
- 11 cm x 10.7 cm x 3.5 cm
- 161 g
- Router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- Authentication Method
- PAP, CHAP, MS-CHAP
- Status Indicators
- Port status, power
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
- Max Transfer Rate
- 24 Mbps
- WAN: 1 x ADSL , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- External power adapter
- 11 cm
- 10.7 cm
- 3.5 cm
- 161 g
- 0 °C
- 40 °C
- 20 - 85%
