Zyxel P-661HNU Wireless N ADSL2+ VPN Router
Quicklinx: 7YQJWS00 Mfr#: 91-004-959005B
The P-661HNU-F1 featuring 802.11n technology provides the ultimate solution for speed and coverage. P-661HNU-F1 provides stable and reliable wireless connections for high speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device.
  • 802.11n technology for extreme performance and coverage
  • Wi-Fi Protection Setup (WPS)
    Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
  • SPI Firewall and IPSec VPN
    The Stateful Packet Inspection (SPI) Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on SPI, Denial of Service (DoS) and DDoS features, the P-661HNU-F1 provides the first-line defense against hackers, network intruders and other harmful threats. Besides, P-661HNU-F1 allows companies to establish Virtual Private Network (VPN) connections with business partners, as well as remote and branch offices. VPN uses data encryption and the Internet to provide transparent, secure communications between two or more sites without the expense of leased site-to-site lines. The P-661HNU-F1 provides VPN connection with IPSec technology.
  • TR-069 remote management
    With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "Plug and Play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
  • 3G WAN backup support
    With the built-in USB interface for a 3G dongle, the P-661HNU-F1 can offer you the flexibility to share either a 3G WAN or a xDSL connection with all users in your network when either connection is available without any configuration required.
Zyxel Prestige 661HNU-F1 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Simultaneous NAT sessions: 6000 , Concurrent IPSec VPN tunnels: 2 , IPSec VPN tunnels: 10
Network / Transport Protocol
IPSec
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
NAT support, VPN support, DoS attack prevention, packet filtering, ALG support, dynamic DNS server, print server, URL filtering, Access Point operational mode, IPSec VPN, file sharing, event log, WPS, WAN failover, DHCP server, 3G USB Dongle Support, DHCP relay, SPIF, DHCP client
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
26 cm x 13.5 cm x 4.2 cm
400 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
IPSec
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, CSA, FCC, RoHS, IEC 60950-1, EN 60950-1
Status Indicators
Power, WLAN, WAN, LAN, USB, ADSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex L
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
2 dBi
External power adapter
26 cm
13.5 cm
4.2 cm
400 g
20 - 85% (non-condensing)
