Zyxel P-660HN-T1A Wireless N ADSL2+ Router
Quicklinx: 79WWWS00 Mfr#: 91-004-961002B
802.11n Technology for extreme performance and coverage
The P-660HN-T Series featuring 802.11n Technology provides the ultimate solution for speed and coverage. With data rate up to 150 Mbps, the P-660HN-T Series provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11b/g Wi-Fi certified device.
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall Security
The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), DoS (Denial of Service) and DDoS features, the P-660HN-T Series provides the first-line defense against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
The P-660HN-T Series comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
TR-069 remote management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "plug-and-play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
  • 802.11n technology for extreme performance and coverage
    The P-660HN-T Series featuring 802.11n technology provides the ultimate solution for speed and coverage. With data rate up to 150Mbps, the P-660HN-T Series provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11b/g Wi-Fi certified device.
  • Wi-Fi Protection Setup (WPS)
  • Robust SPI firewall security
    The SPI firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), DoS (Denial of Service) and DDoS features, the P-660HN-T Series provides the first-line defense against hackers, network intruders and other harmful threats.
  • Quality of Service (QoS) support
  • TR-069 remote management
Zyxel Prestige 660HN-T1A - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Simultaneous NAT sessions: 2048
Network / Transport Protocol
PPTP, IPSec, PPPoE
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, HTTPS
Firewall protection, DHCP support, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, ALG support, dynamic DNS server, URL filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup
13.3 cm x 6.1 cm x 16.3 cm
215 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, IPSec, PPPoE
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, CSA, FCC
Status Indicators
Power, link/activity
Communications
DSL modem
Protocols & Specifications
ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
Max Transfer Rate
24 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
External power adapter
13.3 cm
6.1 cm
16.3 cm
215 g
20 - 85% (non-condensing)
