Zyxel P-660H-D1 4 Port ADSL2+ Router
Quicklinx: 75Q0WS00 Mfr#: 91-004-582024B
Cost-effective Ultra High-Speed ADSL2+ Gateway for SOHO Networks
Higher Speed Internet Access
The ZyXEL P-660H Series is an all-in-one affordable router, compatible with high-speed ADSL, ADSL2 and ADSL2+ interfaces over existing copper lines. With speed up to 12Mbps (ADSL2) or 24Mbps (ADSL2+), the P-660H Series offers higher data transfer rates and better bandwidth than traditional ADSL gateways. Users can enjoy not only high-speed ADSL services, but also broadband multimedia applications such as interactive gaming, video streaming, and real-time audio much easier than before.
Media Bandwidth Management (MBM™) Quality of Service (QoS)
The P-660H Series enables network administrators to allocate network resources and to guarantee Quality of Service (QoS). The Media Bandwidth Management (MBM) function prioritizes media services, and increases productivity and efficiency in daily operations by tailoring a system to specific demands such as VoIP, video streaming, video-conferencing or MP3 applications.
Zero Configuration Technology
With Zero Configuration technology, the P-660H Series. installation is quick and simple, allowing users to hook up a DSL connection without hassle.
Robust Firewall Security
The ICSA-certified ZyNOS operating system ensures state-of-art firewall performance and robust security from the P-660H Series. Based on Stateful Packet Inspection (SPI), DoS (Denial of Service) and DDoS features, it provides the first line defense against hackers, network intruders, and other harmful threats.
UPnP Support
The P-660H Series supports UPnP discovery and UPnP NAT traversal. Using the standard TCP/IP protocol, the P-660H Series can join a network, obtain an IP address, convey its capabilities, and learn about other devices on the network.
Zyxel Prestige 660H-D1 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL Lite, ADSL, ADSL2, ADSL2+, READSL
WAN Ports Qty
1
Ethernet, Fast Ethernet
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP
Remote Management Protocol
SNMP, Telnet, HTTP
Firewall protection, DHCP support, ARP support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, content filtering, packet filtering, dynamic DNS server, VPN passthrough, firmware upgradable, DDos attack prevention, MBM, Zero Configuration Technology, MAP
IEEE 802.1D, UPnP
18 cm x 12.8 cm x 3.6 cm
325 g
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
SNMP, Telnet, HTTP
IEEE 802.1D, UPnP, FCC
Status Indicators
Status
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
18 cm
12.8 cm
3.6 cm
325 g
50 °C
20 - 95%
