Upgrade Wireless Performance for Home Connection
The ZyXEL NWD6505 Dual-Band Wireless AC600 USB Adapter delivers data transfer rates of up to 150 Mbps* at 2.4 GHz or 433 Mbps* at 5 GHz. It not only provides high-speed network capability but also works with your existing 802.11 a/b/g/n wireless Routers or Access Points.
Dual-band support for stable wireless networks
The ZyXEL NWD6505 provides selectable dual-band (2.4 GHz or 5 GHz) wireless signals for users to enjoy better network connections. The 5 GHz band is ideal for media-centric applications such as HD video streaming or online gaming, while the 2.4 GHz band is suitable for Internet browsing and VoIP telephony without performance degradation.
Easy security setup
Instant security with WPS allows you to create a secure wireless network with a touch on a single button.
Portability with Elegance
The compact, lightweight design of the ZyXEL NWD6505 offers excellent portability for road warriors and others on the move. Users can easily plug a NWD6505 into a USB port on a desktop or laptop to upgrade the network speed instantly. It includes an USB extension cable that enables the user to position the NWD6505 for maximum connectivity.
Latest 802.11ac wireless technology for data transfer rates of up to 433 Mbps
With the 802.11ac wireless standard, the ZyXEL NWD6505 provides high-throughput wireless network data transfer rates of up to 150 Mbps at 2.4 GHz or 433 Mbps at 5 GHz. It's better for wireless video streaming and web browsing performance, and backward compatible with all your current wireless routers or access points. -
Optimized HD media experience with clutter-free dual-band networks
The ZyXEL NWD6505 provides selectable dual-band wireless signals for users to enjoy better network connections. The 5 GHz band is ideal for media-centric applications such as HD video streaming or online gaming, while the 2.4 GHz band is suitable for Internet browsing and VoIP telephony without performance degradation. -
Easy setup with Wi-Fi Protected Setup (WPS)
Instant security with WPS allows you to create a secure wireless network with a touch on a single button. -
Portability with elegance
- Zyxel NWD6505 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 5.8 cm x 2.1 cm x 1.1 cm
- 8 g
- Data Link Protocol
- 802.11ac
- Data Transfer Rate
- 600 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- System Requirements
- Apple MacOS X 10.6, Apple MacOS X Lion 10.7, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions), Apple MacOS X 10.8
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 600 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Cables Included
- 1 x USB extension cable (external)
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- IC, FCC, LVD
- 1.25 Watt
- OS Required
- 5.8 cm
- 2.1 cm
- 1.1 cm
- 8 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
