ZyXEL NWD2205 Wireless N USB2.0 Adapter
Quicklinx: 7Q16WS00 Mfr#: 91-005-354001B
The compact, lightweight design of NWD2205 offers excellent portability. Users can easily plug NWD2205 to a USB connector on desktop or laptop computers to upgrade the network speed instantly. In addition, with bundled USB cable users can easily adjust the direction of NWD2205.
The ZyXEL NWD2205 USB adapter brings you faster wireless connection. With the data transfer rate of up to 300 Mbps, which is over 5 times faster than the 802.11g standard, the NWD2205 offers you the high-speed connection everywhere under Wi-Fi coverage. It not only provides a high-speed network capability, but also works with your existing 802.11b/g network.
  • Ultra-compact design for optimal portability
  • 802.11n compliance with data transfer rates of up to 300 Mbps
  • Soft AP feature for sharing wireless Internet access
    With the built-in soft AP function, the NWD2205 can help users to create wireless networks instantly. Just plug NWD2205 into a desktop or laptop computer connecting to a cable or xDSL modem, all other wireless-capable devices can connect to the Internet through the NWD2205.
  • Wi-Fi WMM certified for prioritizing multimedia streaming
    With WMM QoS support, the NWD2205 is an excellent solution for you to deliver time-sensitive applications such as video and voice streaming. It significantly enhances your experience on audio, video and voice applications by prioritizing data traffic, so you can enjoy and share multimedia contents with your family or friends without interruption.
  • One-touch WPS button for easy wireless security setup
    Establishing a secure wireless network is no longer a hassle. The WPS (Wi-Fi Protected Setup) feature takes just a few seconds to set up a secure wireless network without complicated procedures. A click on the WPS button is all it needs to set up a secure wireless network easily.
  • Green adapter saves energy effortlessly
    The ZyXEL NWD2205 brings you not only a plug-and-play wireless solution but also a smart way to save energy. Without complicated setup, just plug the NWD2205 into your laptop or PC, and it automatically adjusts wireless output power by detecting the distance from the device to the wireless access point. If the PC equipped with NWD2205 is close to the wireless access point, NWD2205 lowers the output power to reduce power consumption. When there is no transmission traffic, the NWD2205 will enter the power-saving mode to save electricity.
Zyxel NWD2205 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
3.6 cm x 1.8 cm x 0.6 cm
3 g
802.11b/g/n
Data Transfer Rate
300 Mbps
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup
Apple MacOS X 10.4.x, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x
Microsoft Certification
Compatible with Windows 7
3-year warranty
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Status Indicators
Link/activity
Software access point, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
1 x USB extension cable
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
WHQL, IC, FCC, RoHS
3.6 cm
1.8 cm
0.6 cm
3 g
Limited warranty - 3 years
50 °C
20 - 90% (non-condensing)
