Zyxel NWA90AX, Standalone / NebulaFlex Wireless Access Point
Quicklinx: HHZ2WS00 Mfr#: NWA90AX-EU0102F
The NWA90AX is an excellent choice for small and medium-sized businesses that want to benefit from an ax11 (WiFi 6) access point at the best possible price. It supports both 2.4 and 5 GHz frequencies, so you can make the most of everything WiFi 6 has to offer: higher speeds, even in dense environments, wider coverage and greater IoT deployment capability.
  • No network expertise required
    The NWA90AX can be installed and configured by anyone, whether in small hotels, cafés, telecommuting configurations, stores or businesses. It supports local management via web interface or Nebula cloud management. With just a few clicks, you can quickly set up your access point and easily create a network for your staff and another for guests, so you can immediately enjoy your new ultra-fast WiFi 6 network.
  • Secure WiFi authentication for enhanced business protection
    With support for captive portal and IEEE802.1x authentication, the NWA90AX offers small and medium-sized businesses not only enterprise-grade security to protect their networks, but also the ability to customize the WiFi network user login for marketing and corporate recognition.
  • You're in charge
    The NebulaFlex-enabled NWA90AX gives you the freedom to choose how you manage your network. With an intuitive web interface on your PC or Nebula's super-easy cloud management, you'll never forget a username, password or IP address again.
Zyxel NWA90AX - radio access point - Wi-Fi 6 - cloud-managed
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 1200 Mbps
Mounting screws, mounting plate
Power Over Ethernet (PoE) Supported
PoE+
AC 100-240 V (50/60 Hz)
14 cm x 14 cm x 3.75 cm
290 g
Radio access point
14 cm
14 cm
3.75 cm
290 g
External
Wireless
Data Transfer Rate
1775 Mbps
Network / Transport Protocol
IPv6
Remote Management Protocol
HTTP, CLI
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Performance
VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Multimedia (WMM) support, rogue access point detection, dual-stream (2x2), MU-MIMO technology, Unscheduled Automatic Power Save Delivery (U-APSD), band steering, Fast Roaming, Dynamic Channel Selection (DCS), Layer 2 isolation, Smart Mesh technology
Encryption Algorithm
WPA2-PSK, WPA2-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax
Aerial
Antenna
Internal
Antenna Qty
2
1 x 1000Base-T (PoE+) - RJ-45
MTBF
1,010,980 hours
BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, EN 301 489-1, LP0002, CNS 14336-1, ETSI EN 300 328, EN 301 893, EN 301 489-17
PoE+
External power adapter
Shipping Width
24 cm
Shipping Depth
15.5 cm
Shipping Height
6 cm
Shipping Weight
600 g
50 °C
10 - 90% (non-condensing)
