Zyxel NWA50AX, Standalone / NebulaFlex Wireless Access Point
Quicklinx: HHZ0WS00 Mfr#: NWA50AX-EU0102F
More than 50 In Stock
£56.37 ex VAT
£67.64 inc VAT
The Zyxel NWA50AX is the true WiFi 6 access point that comes with the right-fit feature set for small businesses and SoHo users looking to upgrade to 11ax (WiFi 6) without an expensive price tag. Supporting both 2.4Ghz and 5Ghz frequencies, the AP is aimed to empower you to enjoy all the best things WiFi 6 has to offer such as faster speeds even when congested or in high-density environments, expanded range in your wireless network, increased capacity for IoT deployments, and a lot more.
  • No networking expertise required
    The NWA50AX can be easily installed and configured by everyone in small hotels, coffee shops, home offices, or boutique/retail stores. It supports both local GUI management and Nebula Cloud networking management, the simple setup allows you to quickly configure the AP with only a few clicks, making it super easy to set up guest and employee network on your own and start enjoying the ultra-fast Wi-Fi 6 speeds in no time.
  • Easy Networking for Uncompromised Security
    The average user is more likely to favor using the easiest method to get their network set up quickly than dealing with complex configurations, resulting in insecure encryption with compromised security. Supporting the latest WPA3 Personal standard, the NWA50AX is designed to bring stronger encryption to protect your wireless network without complicated configurations.
  • Manage it your way
    The NWA50AX with NebulaFlex offers the flexible manageability for you to freely choose between the local GUI management or onboarding to super easy Nebula cloud management interface that you never need to worry about forgetting the IP address or lost account and password whatsoever.
Zyxel NWA50AX - radio access point - Wi-Fi 6
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 1200 Mbps
Mounting screws, mounting plate
Power Over Ethernet (PoE) Supported
PoE+
AC 100-240 V
14 cm x 14 cm x 3.75 cm
290 g
Radio access point
14 cm
14 cm
3.75 cm
290 g
External
Wireless
Network / Transport Protocol
IPv6
Frequency Band
2.4 GHz, 5 GHz
Performance
Band steering, Fast Roaming, 2x2 MIMO technology, Mesh networking, Wireless Distribution System (WDS) support, VLAN support, Wi-Fi Multimedia (WMM) support, Unscheduled Automatic Power Save Delivery (U-APSD), Dynamic Channel Selection (DCS)
Encryption Algorithm
WPA-Personal, WPA2-Personal, WPA3-Personal
IEEE 802.3at
1 x 1000Base-T (PoE+) - RJ-45
MTBF
1,010,980 hours
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, BSMI CNS 14336-1, EN 301 489-1, ETSI EN 300 328, EN 301 893, EN 301 489-17
PoE+
External power adapter
AC 100-240 V
16 watt
Shipping Width
24 cm
Shipping Depth
15.5 cm
Shipping Height
6 cm
Shipping Weight
600 g
50 °C
10 - 90% (non-condensing)
Brand: Zyxel
