The Zyxel NWA50AX is the true WiFi 6 access point that comes with the right-fit feature set for small businesses and SoHo users looking to upgrade to 11ax (WiFi 6) without an expensive price tag. Supporting both 2.4Ghz and 5Ghz frequencies, the AP is aimed to empower you to enjoy all the best things WiFi 6 has to offer such as faster speeds even when congested or in high-density environments, expanded range in your wireless network, increased capacity for IoT deployments, and a lot more.
No networking expertise required
The NWA50AX can be easily installed and configured by everyone in small hotels, coffee shops, home offices, or boutique/retail stores. It supports both local GUI management and Nebula Cloud networking management, the simple setup allows you to quickly configure the AP with only a few clicks, making it super easy to set up guest and employee network on your own and start enjoying the ultra-fast Wi-Fi 6 speeds in no time. -
Easy Networking for Uncompromised Security
The average user is more likely to favor using the easiest method to get their network set up quickly than dealing with complex configurations, resulting in insecure encryption with compromised security. Supporting the latest WPA3 Personal standard, the NWA50AX is designed to bring stronger encryption to protect your wireless network without complicated configurations. -
Manage it your way
The NWA50AX with NebulaFlex offers the flexible manageability for you to freely choose between the local GUI management or onboarding to super easy Nebula cloud management interface that you never need to worry about forgetting the IP address or lost account and password whatsoever.
- Zyxel NWA50AX - radio access point - Wi-Fi 6
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum data rate (2.4 GHz): 575 Mbps ¦ Maximum data rate (5 GHz): 1200 Mbps
- Included Accessories
- Mounting screws, mounting plate
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- AC 100-240 V
- 14 cm x 14 cm x 3.75 cm
- 290 g
- 14 cm
- 14 cm
- 3.75 cm
- 290 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- IPv6
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Band steering, Fast Roaming, 2x2 MIMO technology, Mesh networking, Wireless Distribution System (WDS) support, VLAN support, Wi-Fi Multimedia (WMM) support, Unscheduled Automatic Power Save Delivery (U-APSD), Dynamic Channel Selection (DCS)
- Encryption Algorithm
- WPA-Personal, WPA2-Personal, WPA3-Personal
- IEEE 802.3at
- 1 x 1000Base-T (PoE+) - RJ-45
- MTBF
- 1,010,980 hours
- EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, BSMI CNS 14336-1, EN 301 489-1, ETSI EN 300 328, EN 301 893, EN 301 489-17
- PoE+
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 16 watt
- Shipping Width
- 24 cm
- Shipping Depth
- 15.5 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 600 g
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
