Zyxel NWA220AX-6E, Single Pack 802.11axe AP
Quicklinx: HHYZWS00 Mfr#: NWA220AX-6E-EU0101F
2.5X more capacity with the new 6GHz band
Delivering up to 5.4Gbps speed, the Zyxel NWA220AXE-6E is fully equipped with the next-gen WiFi 6E technology for ultra-fast speeds and low-latency connections.
Flexible BandFlex radio design
The Zyxel NWA220AX-6E is the dual-radio access point with a BandFlex radio design that can support either 5GHz or 6GHz by configuration, making it the most economical choice to fit into your existing 5GHz coverage as well as futureproofing the use of 6GHz.
Zyxel 6E Boost
The high-gain 4x4 streams in 6GHz design helps increase the maximum gains in transmit beamforming and receive MIMO to extend range and maximize the performance of the new band.
NWA220AX-6E for High-density WiFi
WiFi 6E, the new 6 GHz band, presents a solution to quenching the thirst for today’s hunger for more bandwidth. The NWA220AX-6E’s BandFlex radio design allows the AP to support either 5GHz or 6GHz band by configuration, making it the most economical choice to fit into your existing 5GHz coverage, as well as futureproofing the use of 6Ghz.
Zyxel NWA220AX-6E - radio access point - Wi-Fi 6 - cloud-managed
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz, 6 GHz
Performance
Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 4800 Mbps , Maximum data rate (6 GHz): 4800 Mbps
Mounting screws, mounting plate
Power Over Ethernet (PoE) Supported
PoE+
DC 12 V
18 cm x 18 cm x 4.2 cm
650 g
Radio access point
18 cm
18 cm
4.2 cm
650 g
Europe
External
Wireless
Network / Transport Protocol
IPv6
Remote Management Protocol
SNMP
Cloud-Managed
Frequency Band
Performance
Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Advanced Cellular Coexistence (ACC), cloud managed, ZyXEL wireless optimizer (ZWO), MU-MIMO technology, Unscheduled Automatic Power Save Delivery (U-APSD), band steering, Fast Roaming, Dynamic Channel Selection (DCS), ZON Utility, L2-isolation, rogue AP detection
Encryption Algorithm
WPA, WPA2, WPA2-PSK, WEP, WPA3, WPA3-Enterprise
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 2, IEEE 802.11ax
Aerial
Antenna
Internal
Gain Level
6 dBi
1 x 1/2.5GBase-T (uplink, PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45
MTBF
711,333 hour(s)
EN55022, EN55024, FCC Part 15 B, FCC Part 15 C, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, BSMI CNS 14336-1, EN 301 489-1, LP0002, ETSI EN 300 328, EN 301 893, IEEE 802.3af, IEEE 802.3at, EN 301 489-17, IEEE 802.3bt, EN 62368, EN 303 687
PoE+
External power adapter (not included)
DC 12 V
21 watt
Shipping Width
19.7 cm
Shipping Depth
19 cm
Shipping Height
6 cm
Shipping Weight
780 g
50 °C
10 - 95% (non-condensing)
