Zyxel NBG-5615 Simultaneous Dual-Band Wireless N750 Media Router
Quicklinx: 8JL2WS00 Mfr#: NBG5615-EU0101F
Highly Advanced Router Optimizes for HD Media Streaming
The ZyXEL NBG5615 Simultaneous Dual-Band Wireless N750 Media Router is compliant with 802.11n to enable high-performance, simultaneous multimedia streaming, gaming and file sharing among multiple home users. The dual-band network capability allows users to set up home wireless environment with the maximum flexibility for concurrent optimized HD media and web surfing.
Dual-band support offering a stable wireless network
The ZyXEL NBG5615 provides more stable and reliable wireless connections for your home network at speeds of up to 750 Mbps* over the concurrent dual-band network. The NBG5615 works on the interference-free 5 GHz for smooth video streaming and gaming in addition to the essential 2.4 GHz for web surfing and file transferring at the same time to fulfill different applications demands.
DLNA support for easy home media sharing
The DLNA-supported ZyXEL NBG5615 enables sharing of digital media such as music, photos and videos through the networking environment among DLNA compatible devices like media players, laptops, smart TVs and smart phones by facilitating the compatibility of these network devices. Just plug your USB storage device into the NBG5615 and enable media streaming to the TV with mobile control.
Advanced Quality of Service (QoS) offers high media streaming stability
For users who demand greater bandwidth for high-speed services, the ZyXEL NBG5615's advanced QoS enhances stability of multiple HD video streams, gaming, VoIP audio and web surfing.
Hardware-accelerated Network Address Translation (NAT) for high network performance
The ZyXEL NBG5615 offers better routing performance via its hardware-accelerated NAT. This allows multiple networking devices throughout the entire house to enjoy better video streaming, online gaming and data transfer with whole-home coverage.
Simple mass storage sharing via USB ports
The ZyXEL NBG5615 allows users to share USB devices over the home network. The NBG5615 features two USB ports to allow users to share printers or USB mass storage devices. Just plug the USB devices to the NBG5615, and family members throughout the house can enjoy media steaming on their PC, laptop or mobile devices.
  • Dual-band support offering a stable wireless network
    The ZyXEL NBG5615 provides more stable and reliable wireless connections for your home network at speeds of up to 750 Mbps over the concurrent dual-band network. The NBG5615 works on the interference-free 5 GHz for smooth video streaming and gaming in addition to the essential 2.4 GHz for web surfing and file transferring at the same time to fulfill different applications demands.
  • DLNA support for easy home media sharing
  • Advanced Quality of Service (QoS) offers high media streaming stability
  • Hardware-accelerated Network Address Translation (NAT) for high network performance
  • Simple mass storage sharing via USB ports
Zyxel NBG5615 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, SMB, DDNS
Routing Protocol
IGMPv2, IGMP
DMZ port, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, static IP mode, bandwidth control, DLNA Media Server, on/off switches, DHCP client, NetUSB support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP
18.6 cm x 12 cm x 3 cm
308 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP, EMC, FCC, LVD
Status Indicators
Power, WAN, LAN, wireless, USB, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
16 Watt
1 x network cable
Europe
Software Included
Drivers & Utilities
18.6 cm
12 cm
3 cm
308 g
10 - 90% (non-condensing)
