The ZyXEL NBG-418N Wireless N home router provides more stable and reliable wireless connections for web surfing, Internet sharing and multimedia streaming. Better yet, its rich green features will bring you an energy-saving wireless network without compromising performance.
Better wireless experience
Compliant with 802.11n technology, the ZyXEL NBG-418N Wireless N home router can upgrade home networks with faster wireless speeds of up to 300 Mbps to provide more stable and reliable wireless connections for Web surfing and multimedia streaming. With Wi-Fi Multimedia (WMM) technology, the NBG-418N enhances your audio, video and voice application experience over wireless networks through the capability to prioritize different network traffic types for optimized performance. -
Secured wireless environments
With the Wi-Fi Protected Setup (WPS) push button, establishing a secure wireless network can't be easier. The WPS takes only a few seconds to set up a secure wireless network without any complicated procedure; and 64/128-bit WEP and WPA-PSK/WPA2-PSK are also supported to provide stringent protection for wireless transmissions. -
Saves energy in smart ways
Featuring a power-saving mode, the NBG-418N can automatically reduce wasted energy when there is no transmission traffic. In addition, the NBG-418N can also detect the length of connected Ethernet cables and then adjust power usage accordingly. The shorter the Ethernet cable length, the less power it consumes.
 - Zyxel NBG-418N - v2 - wireless router - Wi-Fi - desktop
 - Wireless router - 4-port switch (integrated)
- Enclosure Type
 - Desktop
- WAN Ports Qty
 - 1
- Data Link Protocol
 - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
 - 300 Mbps
 - PPTP, L2TP, IPSec, PPPoE, DHCP
- Routing Protocol
 - Static IP routing
 - Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), repeating mode, DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, bandwidth control, DHCP client
 - IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
 - 14.2 cm x 10.2 cm x 2.3 cm
 - 148 g
- Localisation
 - United Kingdom
- Enclosure Type
 - Desktop
- Connectivity Technology
 - Wireless, wired
 - 300 Mbps
- Routing Protocol
 - Static IP routing
- Encryption Algorithm
 - 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
 - IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, BSMI, FCC, RoHS, LVD
- Status Indicators
 - Power, WLAN, WAN, WPS
 - LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
 - External integrated
- Antenna Qty
 - 2
- Directivity
 - Omni-directional
- Gain Level
 - 5 dBi
- Power Device
 - External power adapter
 - 3.5 Watt
- Cables Included
 - 1 x network cable
- Localisation
 - United Kingdom
 - 14.2 cm
 - 10.2 cm
 - 2.3 cm
 - 148 g
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
