NAS540 4-Bay Personal Cloud Storage
- Backup everything with complete protection
- Blade-speed performance access to all your data
- Create a personalized cloud for anywhere access
Your Choice for Reliable and Secure Personal Cloud Storage
Create a personal cloud with ZyXEL's NAS540 4-Bay Personal Cloud Storage server. Enjoy the freedom to bring large amounts of documents and multimedia files along with your mobile devices where Internet connection is available. Sync your mobile devices easily with popular cloud platforms including Google Drive™**, Memopal, ownCloud or ZyXEL's new zCloud 2.0. Equipped with RAID-5 configuration and dual Ethernet ports for link aggregation support, the ZyXEL NAS540 can deliver up to 130 MB/sec of reading and 48 MB/sec writing speeds.
Personal cloud for easy remote file access, backup, syncing and sharing
The ZyXEL NAS540 gives you the ability to access your cloud storage anytime and anywhere. ZyXEL zCloud 2.0 enables you to view and access your multimedia contents on the NAS540 remotely through Android or iOS mobile devices. Through ownCloud support, you can also remotely access and sync files on Windows, Mac OS X, Android, iOS and even Linux** computers. Instant Picture Upload automatically backs up your photos from your mobile device, and you can create public Web links with ownCloud to easily share files with friends, families or co-workers.
High-performance networking hardware
The 1.2 GHz dual-core CPU and 1 GB of DDR3 RAM enables the ZyXEL NAS540 to handle intensive network data management tasks. The two Ethernet LAN ports with link aggregation capability deliver the best data transfer speeds on your network. The fast USB 3.0 ports provide external storage devices with data transfer rates of up to 4.8 Gbps, making backup tasks a snap. An SD card slot with the latest SDXC support is included for you to easily transfer new photos to the ZyXEL NAS540.
Cool, quiet design for silent operations
The ZyXEL NAS540 is designed to keep your drives cool for increased product life. The 120 mm fan allows it to push more air to cool down the drives without the annoying noise from high-speed, smaller fans. With 27 dB sound level from the 100 cm distance, the NAS540 is whispering quiet and it gives you the freedom to place the device anywhere without disturbing the environment.
Rock-solid data protection
Protect your personal data with RAID 1, 5, 6 or 10. With RAID support, the ZyXEL NAS540 can protect your personal data from hard disk failures. In case any one of the disks failed, you can still access your data safely and restore the normal RAID protection with the failed disk replaced.
Intelligent desktop with easy graphic interface
The latest intelligent desktop offers a smooth, user-friendly graphic interface that allows you to easily view and manage the applications on your ZyXEL NAS540. Check your NAS540 health status, including CPU utilization and fan speed, with its intuitive Web GUI to ensure the network storage is running reliably.
Stream multimedia contents with AirPlay* or Chromecast™
Bring your favorite multimedia files on the ZyXEL NAS540 to the big screen. With apps like BubbleUPnP, Avia, Samsung TV Media, or ZyXEL zCloud v2.1*, you can play your favorite videos, music or photos on the big screen with connected streaming devices such as AppleTV or Chromecast.
USB 3.0 and SDXC support for fast backup
The USB 3.0 ports provide a fast interface for external storage with data transfer rates of up to 4.8 Gbps to make backup tasks a snap. An SD slot with the latest SDXC support is included for you to transfer new photos to the ZyXEL NAS540 easily.
Screw-less design makes setup a snap
Put your toolbox away. The ZyXEL NAS540's design requires no screws, making drive installation quick and easy. The device supports four 2.5" or 3.5" SATA II hard drives in a mirrored RAID 5 configuration, offering up to 4TB of storage.
The 1.2 GHz dual-core CPU and 1 GB of DDR3 RAM enables the ZyXEL NAS540 to handle intensive network data management tasks. The two Ethernet LAN ports with link aggregation capability deliver the best data transfer speeds on your network. The fast USB 3.0 ports provide external storage devices with data transfer rates of up to 4.8 Gbps, making backup tasks a snap. An SD card slot with the SDXC support is included for you to easily transfer photos to the ZyXEL NAS540. -
The ZyXEL NAS540 is designed to keep your drives cool for increased product life. The 120 mm fan allows it to push more air to cool down the drives without the annoying noise from high-speed, smaller fans. With 27 dB sound level from the 100 cm distance, the NAS540 is whispering quiet and it gives you the freedom to place the device anywhere without disturbing the environment. -
Protect your personal data with RAID 1, 5, 6 or 10. With RAID support, the ZyXEL NAS540 can protect your personal data from hard disk failures. In case any one of the disks failed, you can still access your data safely and restore the normal RAID protection with the failed disk replaced. -
The intelligent desktop offers a smooth, user-friendly graphic interface that allows you to easily view and manage the applications on your ZyXEL NAS540. Check your NAS540 health status, including CPU utilization and fan speed, with its intuitive Web GUI to ensure the network storage is running reliably. -
Stream multimedia contents with AirPlay or Chromecast
Bring your favorite multimedia files on the ZyXEL NAS540 to the big screen. With apps like BubbleUPnP, Avia, Samsung TV Media, or ZyXEL zCloud v2.1, you can play your favorite videos, music or photos on the big screen with connected streaming devices such as AppleTV or Chromecast. -
The USB 3.0 ports provide a fast interface for external storage with data transfer rates of up to 4.8 Gbps to make backup tasks a snap. An SD slot with the SDXC support is included for you to transfer photos to the ZyXEL NAS540 easily. -
Put your toolbox away. The ZyXEL NAS540's design requires no screws, making drive installation quick and easy. The device supports four 2.5" or 3.5" SATA II hard drives in a mirrored RAID 5 configuration, offering up to 4TB of storage. -
Create a reliable and scalable storage environment at home with iSCSI
Now you can easily create your own NAS home network storage server. Your system identifies the iSCSI network target as a local drive, enabling you to connect your NAS box as if it was physically inside your computer. You can leverage your computer's built-in iSCSI tool to achieve faster performance from your local network storage. Better still, iSCSI allows home users to consolidate storage into a data center array, giving hosts the appearance of locally attached disks.
- Zyxel NAS540 - personal cloud storage device
- Personal cloud storage device
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 19 cm x 22.5 cm x 16 cm
- 3.8 kg ()
- Processor
- 1 x Freescale 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Card Reader
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 19 cm
- 22.5 cm
- 16 cm
- 3.8 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDXC Memory Card
- Data Link Protocol
- NTP, PPPoE, FTP, DHCP, SMB
- Network Services Compatibility
- DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), HTTP, HTTPS
- LDAP support, dynamic DNS server, firmware upgradable, MySQL server, web server, backup server, iTunes server, FTP server, UPnP Media Server, reset button, Apple Time Machine compatible, Receive Side Scaling (RSS), WebDAV server, Dropbox support, DLNA 1.5 support
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 4 (total) / 4 (free) x internal - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), UPS support
- FCC Class B certified, C-Tick, BSMI, LVD
- Power Device
- External power adapter
- Voltage Required
- 36.5 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
