Zyxel Multy M1 WSM20 GB 3 Pack AX1800
Quicklinx: HB1BWS00 Mfr#: WSM20-GB0301F
Suffering from poor wireless connectivity at home with your old router? Eliminate the frustration by providing a powerful network with wider coverage and stronger signal strength.
Optimized Mesh powered by WiFi 6
Multy M1 equipped with the latest WiFi 6 technology which has been designed to offer faster and ef?cient connections especially in device dense environments.
Massive Capacity
4 times data capacity to servemore connected networking devices
Maximum Speed
Insanely fast WiFi throughput for improved gaming, streaming, and smart home experience
More Efficiency
OFDMA, DL/UL MU-MIMO improving traf?c efficiency. Suitable for high bandwidth applications and large packet transmission
Seamless roaming, one WiFi name
Multy creates a single wireless network name and password, allowing you to roam, work and play freely throughout your home without the need to reconnect to another network.
Flexible wired and wireless connection
Operate your local network at full capacity with Gigabit solution! Each Multy M1 device equipped with four gigabit Ethernet LAN ports, which can be used to connect to more devices like media servers, NAS storage devices, switches, and other Smart Home devices.
Zyxel Multy M1 WSM20 - Wi-Fi system - Wi-Fi 6 - desktop, wall-mountable
Wi-Fi system - mesh
Enclosure Type
Desktop, wall-mountable
Wi-Fi System Components
3 routers
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
SSIDs total: 3
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS, IPv4, IPv6, OpenVPN
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Intelligent Assistant
Alexa
NAT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, MAC address filtering, parental control, WMM support, ACS, WPS, IPSec passthrough, DHCP server, Multiple SSID support, reset button, DHCP client, dual-stream (2x2), VPN Server, PPTP passthrough, SSO support, L2TP passthrough, MU-MIMO technology, beamforming technology, Multicast to Unicast Conversion, band steering, VPN client, push notification, router mode, LED on/off button, guest access, bridge mode, OFDMA, WPS button, auto firmware update, guest Wi-Fi, traffic separation from host network, AP steering
13.3 cm x 19.2 cm x 6.6 cm
254 g
Wi-Fi system - mesh - 3-port switch (integrated)
3 routers
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
SSIDs total: 3
Routing Protocol
Encryption Algorithm
WPA3-PSK
Authentication Method
Radio Service Set ID (SSID)
Wi-Fi Rating
AX1800
Mesh Networking
BSMI, FCC, LVD, NCC
1 x 880 MHz
RAM
256 MB
Flash Memory
128 MB
Status Indicators
Status
Line Properties
Line Coding Format
1024 QAM
Internet of Things (IoT)
Alexa
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
15 Watt
3 x wall mounting kits
Network cable
13.3 cm
19.2 cm
6.6 cm
254 g
10 - 90% (non-condensing)
