Zyxel MS7206S 6 Slot Chassis Switch PoE Bundle
Quicklinx: 8PF3WS00 Mfr#: 96-996-000037
The ZyXEL MS-7206S modular chassis switch comes with intelligent L2/L3/L4 local switching and advanced management features. OSPF ensures rapid determination of best routes (convergence), avoid routing loops. Rapid spanning tree provides Layer 2 resilience and prevent loops. VRRP ensures hosts (PCs) have uninterrupted service from default gateway.
  • Unbeatable performance and scalability
    Implement campus and building backbone networks support thousands of users.
  • Fault-free with automatic recovery
  • Secured connectivity
    Sophisticated Layer 2 to Layer 4 ACL (Access Control List) makes security policy to be applied at LAN easily.
Zyxel MS-7206S Fibre Bundle - switch - 24 ports - Managed
Switch - 24 ports - L4 - Managed
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 24 x SFP
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, static IP routing, IGMPv3
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, modular design, hot swap module replacement, Layer 4 switching, Layer 3 switching, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, WRR queuing, MAC address filtering, Broadcast Storm Control, firmware upgradable, WFQ, ACL support, QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
43.5 cm x 31.6 cm x 44.7 cm
15.5 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Power, system, status
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x 10Base-T/100Base-TX - RJ-45 management , 1 x RS-232 - 9 pin D-Sub (DB-9) management , Accessory: 1 x RS-232 - 9 pin D-Sub (DB-9) , 24 x SFP (mini-GBIC)
Expansion Slots
6 (total) / 3 (free) x Expansion Slot
Installed Modules Qty (Max)
3 (installed) / 6 (max)
Internal power supply
Installed Qty
2
Max Supported Qty
2
600 Watt
43.5 cm
31.6 cm
44.7 cm
15.5 kg
