Zyxel MES-3728 24-port 10/100 L2 Metro Switch
Quicklinx: 8PFRWS00 Mfr#: 91-010-175024B
The MES-3728's high-performance hardware platform and physical features enable service providers to easily extend network topologies, while the robust security and management functions help customers to fulfill differentiated metro Ethernet service needs. The MES-3728 not only represents ZyXEL's entry into the metropolitan Ethernet networking arena, but also demonstrates the company's technical capability on metro Ethernet deployments.
  • Secure multi-service delivery and quality
    The ZyXEL MES-3728 is a carrier-class Ethernet switch based on a high-performance hardware platform with robust security, Quality of Service (QoS) and management features to deliver intelligent connectivity for differentiated metro Ethernet services. With features like VLAN stacking and VLAN translation, it is capable of isolating individual customer traffics from internal signaling of the core networks.
  • Advance mechanical design for metro Ethernet
    Designed for metro Ethernet deployments, The MES-3728 offers high operating temperature tolerance, flexible AC/DC dual-input power source as well as protection against humidity and dust for service providers to extend their networks. Since MES-3728 adopts the "front access" design, technicians can easily wire and maintain outdoor cabinets; the external alarm input/output block connects mechanical cabinet parts to the management networks and offers higher protection to the equipment.
Zyxel MES-3728 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x SFP + 2 x combo Gigabit SFP
Performance
Switching capacity: 12.8 Gbps , Forwarding performance: 9.6 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
ARP support, VLAN support, IGMP snooping, MAC address filtering, firmware upgradable, WFQ, DHCP snooping, ACL support, QoS, temperature / humidity sensor, DHCP relay, IP-MAC binding
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag
AC 120/230 V / DC -48 -60 V (50/60 Hz)
43.8 cm x 22.5 cm x 4.5 cm
3.4 kg
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
24 x 10Base-T/100Base-TX - RJ-45 , 2 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x serial (RS-232) , 1 x console - RJ-45
Internal power supply
MTBF
307,007 hours
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
43.8 cm
22.5 cm
4.5 cm
3.4 kg
65 °C
10 - 99% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
