Evolved Design Enabling Innovative Services.
Mobile technology creates opportunities for new operators to enter networking business with lower investment comparing to building fixed-line infrastructures. To fixed-line operators, mobile network is more important as a backup to offload congested bandwidth for higher customer satisfaction. Mobile network is the trend that operators can never resist. ZyXEL, as a global leader of broadband networking, always stay ahead of the trend to offer the market with innovative designs.
The LTE3300 Series employs LTE — the latest mobile broadband technology with high popularity — to deliver the best possible data rates of up to 150/50 Mbps (DL/UL). With bridge and router modes embedded, the LTE3300 Series is adaptive to all kinds of devices/gateways for seamless integration with your CPE (Customer Premise Equipment) on-hand in a simple yet complete way to meet your needs.
Maximum freedom of mobility.
As LTE markets expand quickly, base station coverage is yet to be completed. The LTE3300 Series supports single- (LTE) and multi-mode (LTE/3G/2G) so you can stay connected even of there is only 3G or 2G services. Besides, the multi-band support also relieves the concern from varied LTE/3G frequencies in different countries. The flexibility of LTE3300 Series keeps you online around the world with the maximum freedom of mobility.
State-of-the-art technology.
The LTE3300 Series employs 3GPP release 9, category 4 — the best practice of LTE technology with 150/50 Mbps (DL/UL) data rates. You can enjoy ultra-fast, flexible wireless connection anywhere within LTE/3G/2G signal coverage.
Embedded bridge/router mode for all devices/gateways.
For network integration, ZyXEL embeds both bridge and router modes into the LTE3300 Series. Users can take advantage of the built-in routing functions in all typical applications, while the bridge mode is designed to work with users’ existing or preferred device such as high-end Wi-Fi Access Points, Small Business Gateways or Enterprise Gateways. With the two built-in modes, the LTE3300 Series can be easily integrated with all kinds of devices/gateways.
High-speed Wi-Fi of up to 300 Mbps.
The LTE3300 Series comes with 802.11n Wi-Fi compatibility, so you can enjoy high-speed Wi-Fi of up to 300 Mbps without additional devices. With the true wireless connection provided by the LTE3300 Series of indoor router, there’s no cabling needed for either LTE WAN or wireless LAN.
- Zyxel LTE3301-Q222 - wireless router - WWAN - 802.11b/g/n - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Cellular Protocol
- GSM, UMTS, LTE
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- NAT sessions: 4096
- PPTP, L2TP, IPSec
- Remote Management Protocol
- HTTP, TR-069
- Firewall protection, NAT support, VLAN support, MAC address filtering, IPv6 support, VPN passthrough, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, wireless bridge mode, reset button, IPv4 support, DHCP relay, DHCP client
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 120/230 V
- 18.6 cm x 12 cm x 3 cm
- 350 g
- Localisation
- Europe
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Capacity
- PPTP, L2TP, IPSec
- HTTP, TR-069
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK
- Status Indicators
- Power, status, signal strength, LTE, Internet
Communications
- Wireless cellular modem
- Cellular Protocol
- GSM, UMTS, LTE
- Max Transfer Rate
- 150 Mbps
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Antenna: 2 x
- Expansion Slots
- 1 (total) / 1 (free) x SIM
Aerial
- Aerial
- External detachable and internal
- Antenna Qty
- 4
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 12 Watt
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 18.6 cm
- 12 cm
- 3 cm
- 350 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
