Zyxel GS2200-8 8-port Gigabit L2 Managed Switch
Quicklinx: 8PDCWS00 Mfr#: GS2200-8-GB0101F
The GS2200-8 series is ideal for secure 100BASE and Gigabit connectivity, and it offers access security, advanced prioritization and traffic-monitoring capabilities. The GS2200 series is easy to use and manage for applications needed to support business operations as well as to increase productivity. The CPU protection feature can greatly reduce the likelihood of malfunctions. ZyXEL iStacking clustering management technology can manage devices across different floors and routing domains to locate other iStacking-capable switches in the same management cluster. This allows administrators to manage up to 24 switches with one single IP address. ZyXEL iStacking greatly reduces operating costs and offers more flexible maintenance of ZyXEL Switches. IT staff can opt for the Web or command line interface to suit their needs, and even encrypt their instructions with SSHv1/v2 and SSL. With these sophisticated functionalities, the IT staff is empowered to build a highly secure and efficient corporate network with minimum effort.
  • Non-blocking GbE performance for modern access networks
    The ZyXEL GS2200 series incorporates a high-performance switching architecture that provides 20 Gbps non-blocking switch fabric, 14.9 million packets per-second forwarding rate and wire-speed performance to connect high performance desktop devices with resources at the heart of the network. For branch offices and SME users, the GS2200 series enables the delivery of converged applications and adapts to changing business needs with flexible configurations.
  • Secure, enhanced management functionality
  • Rich IPv6 and other features built-in for future-proof network expansions
    The great features are not only beneficial for high-density Gigabit Ethernet deployments, but also perfectly suitable for both network cores and edges. Besides, the GS2200 series provides rich features including VLANs, CoS/QoS, Port Trunking, Rapid Spanning Tree, Security (Port Security and 802.1X authentication) and network management to meet evolving SME requirements. Meanwhile, the GS2200 series delivers one of the most cost-effective Gigabit Ethernet solutions to empower Gigabit converged networking for branch offices and SME users.
Zyxel GS2200-8 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 20 Gbps
Virtual interfaces (VLANs): 1024
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, port mirroring, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), bandwidth control, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ)
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
25 cm x 15 cm x 4.4 cm
1.34 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
448 KB
Status Indicators
Port status, power, system, link/activity
10 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x SFP (mini-GBIC) , 1 x serial (RS-232) DB-9
Internal power supply
12.3 Watt
BSMI, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
United Kingdom
25 cm
15 cm
4.4 cm
1.34 kg
50 °C
10 - 90% (non-condensing)
