Zyxel GS1920-24 28-port GbE L2 Smart Switch
Quicklinx: 9LGDWS00 Mfr#: GS1920-24-GB0101F
The small and medium-sized businesses (SMBs) expect a higher level of performance from their networks - more connections to support diverse applications, fewer network disruptions, easier management and a greater degree of network security. The ZyXEL GS1920 series of switches fulfills these expectations with support for 24 non-PoE copper ports, as well as non-blocking performance and high-power budget support to facilitate a greater number of network connections.
The ZyXEL GS1920 series offers network protection features and comprehensive access management functions to establish a reliable and secure network environment. To create a one-network experience, the GS1920 series features inter-device discovery and reset, which along with the ZON utility, reduces the time and effort needed to initialize the network. Easy deployment, smart management and solid security - the GS1920 series is the best solution for SMB networks.
  • Robust network availability
    Network disruptions are a frequent source of headaches for small to medium-sized businesses. Whether outages are caused by internal errors or outside attack, the ZyXEL GS1920 series protects users from network disruptions and ensures uninterrupted connectivity through several key features. Loop Guard helps networks avoid service disruptions caused by switching loops, and IP source guard (IPSG) shields your network from MAC spoof and ARP spoof attacks. Additionally, attacks such as BPDU, ARP and IGMP can target network facilities. However, CPU protection guarantees that a network continues to operate, even while under attack. Furthermore, dual firmware image and configuration features improve network reliability and availability. These are just some of the ways the GS1920 series switches guarantee headache-free network connectivity for SMBs.
  • Rigorous access protection to secure the network
    The ZyXEL GS1920 series provides efficient allocation of network resources while ensuring comprehensive access protection, along with simple and secure network control. Intrusion Lock detects connection status and ensures port security. Not only does the GS1920 series support 802.1x authentication with RADIUS, but it can monitor, filter and police all traffic between clients within the same subnet, creating an even higher degree of security.
  • ZyXEL ONE Network experience
    The ZyXEL GS1920 series utilizes the ZON utility and other interdevice features designed to reduce the time and effort necessary to set up a network. The GS1920 series allows one-click remote management to detect ports that connect neighboring devices while displaying IP information via a Web-based GUI. If a network-connected device like a Wi-Fi access point fails to operate properly, administrators can reset the device to default or power cycle the device from a switch in the Web-based GUI. Additionally, the GS1920 series supports iStacking, which allow 1-IP management to configure, monitor and troubleshoot multiple switches installed at a variety of physical locations.
Zyxel GS1920-24 - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Switching capacity: 56 Gbps , Forwarding performance: 41.67 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
Flow control, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), IGMP proxy, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, ErrDisable Recovery, ZyXEL Discovery Protocol (ZDP), ZyXEL One Network (ZON), IGMP filtering, IGMP throttling
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44.1 cm x 13.1 cm x 4.4 cm
2.17 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, link/activity
28 x 1000Base-T RJ-45 , 4 x SFP
Internal power supply
27.2 Watt
MTBF
211,623 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
United Kingdom
44.1 cm
13.1 cm
4.4 cm
2.17 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
