- Compact, affordable cloud switching solution, comes with 8-Gigabit ports.
- All 8 ports support 802.3at PoE+, with a total of 60W power.
- Supports Nebula to offer a unified cloud network experience, from wired, wireless to security gateway.
- It’s easy to onboard the switch, make real-time configurations, and access to all your cloud devices anywhere, anytime through Nebula APP.
- Slim, and fanless design delivers all-time silent operation for any working environment.
Efficient Performance
With a switching capacity of 16 Gbps and forwarding performance of 11.9 Mbps, the Zyxel GS1915-8EP ensures efficient data flow and high-speed connectivity across the network. -
Advanced Security
Equipped with features like MAC address filtering, SSL encryption, and RADIUS authentication, this switch provides a secure networking environment to protect sensitive data. -
Broad Network Standards Support
Supports a wide range of IEEE standards including 802.1D/Q/ab/p/w/x and 802.3/ab/ad/at/az/u/x, ensuring compatibility and interoperability with existing network infrastructure. -
Smart Power Management
The PoE budget of 60 W along with schedule PoE and energy-efficient Ethernet (IEEE 802.3az) support, allows for optimized power usage and reduced operational costs. -
Versatile Deployment
Fanless design and options for desktop or wall-mountable form factors make the Zyxel GS1915-8EP versatile for various setups, ensuring seamless integration into any business environment.
- Zyxel GS1915 Series GS1915-8EP - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 8
- MAC Address Table Size
- 8K entries
- 2.7 cm
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8
- 8K entries
- Authentication Method
- RADIUS
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
