Zyxel GS1915-8EP, 8-port GbE PoE Smart hybrid mode Switch
Quicklinx: HHYRWS00 Mfr#: GS1915-8EP-GB0101F
Hurry, only 1 left in stock!
£85.51 ex VAT
£102.61 inc VAT
  • Compact, affordable cloud switching solution, comes with 8-Gigabit ports.
  • All 8 ports support 802.3at PoE+, with a total of 60W power.
  • Supports Nebula to offer a unified cloud network experience, from wired, wireless to security gateway.
  • It’s easy to onboard the switch, make real-time configurations, and access to all your cloud devices anywhere, anytime through Nebula APP.
  • Slim, and fanless design delivers all-time silent operation for any working environment.
  • Efficient Performance
    With a switching capacity of 16 Gbps and forwarding performance of 11.9 Mbps, the Zyxel GS1915-8EP ensures efficient data flow and high-speed connectivity across the network.
  • Advanced Security
    Equipped with features like MAC address filtering, SSL encryption, and RADIUS authentication, this switch provides a secure networking environment to protect sensitive data.
  • Broad Network Standards Support
    Supports a wide range of IEEE standards including 802.1D/Q/ab/p/w/x and 802.3/ab/ad/at/az/u/x, ensuring compatibility and interoperability with existing network infrastructure.
  • Smart Power Management
    The PoE budget of 60 W along with schedule PoE and energy-efficient Ethernet (IEEE 802.3az) support, allows for optimized power usage and reduced operational costs.
  • Versatile Deployment
    Fanless design and options for desktop or wall-mountable form factors make the Zyxel GS1915-8EP versatile for various setups, ensuring seamless integration into any business environment.
Zyxel GS1915 Series GS1915-8EP - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8
MAC Address Table Size
8K entries
2.7 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8
8K entries
Authentication Method
RADIUS
2.7 cm
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
