Zyxel GS1915-8, 8-port GbE Smart Switch
Quicklinx: HHYSWS00 Mfr#: GS1915-8-GB0101F
10 In Stock
£47.37 ex VAT
£56.84 inc VAT
The Zyxel GS1915 series two 8-port GbE Smart Managed Layer 2 switches with and without PoE connectivity to the small business network. The GS1915 series supports NebulaFlex which comes with useful features and superior performance. This series is the most cost-effective cloud switch solution for the SB/SMB market. It can be easily configured through Nebula Control Center for unified cloud-based management.
  • Robust performance
    With a switching capacity of 16 Gbps and forwarding performance of 11.9 Mbps, the Zyxel GS1915-8 ensures efficient handling of data across the network, making it ideal for businesses requiring high-speed connectivity.
  • Comprehensive network standards support
    This switch supports a wide range of networking standards, including IEEE 802.1D/Q/ab/p/w/x/3/3ab/3ad (LACP)/3az/3u/3x, ensuring broad compatibility and integration with existing network infrastructure.
  • Advanced security features
    Equipped with RADIUS authentication, SSL encryption, MAC address filtering, and more, the Zyxel GS1915-8 provides a secure networking environment to protect sensitive data from unauthorized access.
  • Efficient network management
    Manageable via SNMP and RMON, and featuring Quality of Service (QoS) for traffic prioritization, the switch offers comprehensive tools for network administration, ensuring optimal performance and reliability.
  • Environmentally friendly design
    The fanless design not only ensures silent operation but also reduces energy consumption, making the Zyxel GS1915-8 an eco-friendly choice for your networking needs.
Zyxel GS1915 Series GS1915-8 - switch - managed - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mbps
Packet buffer size: 525000
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, SSH-2, ICMP, Syslog
Flow control, IGMP snooping, Syslog support, port mirroring, WRR queuing, MAC address filtering, IPv6 support, firmware upgradable, WFQ, STP support, RSTP support, DHCP snooping, QoS, fanless, LACP support, LLDP support, Port Security, DHCP client, SPQ, port isolation, CoS, DSCP support, Storm Control, ICMP, rate limit, DLF, schedule PoE, Loop Guard, Voice VLAN, LLDP-MED, VLAN trunking, MAC freeze, NTP support, MIB support
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 100-240 V (50/60 Hz)
25 cm x 10.4 cm x 2.7 cm
620 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS
Status Indicators
Power, system, link/activity, cloud
8 x 1000Base-T RJ-45
External power adapter
Wall mounting kit
MTBF
1,144,461 hours
EMC, FCC, RoHS, BSMI CNS 13438, LVD, RCM, BSMI CNS 14336-1, EN 62368-1
United Kingdom
25 cm
10.4 cm
2.7 cm
620 g
Shipping Width
30.2 cm
Shipping Depth
22.7 cm
Shipping Height
6.4 cm
Shipping Weight
1.1 kg
Limited warranty - lifetime
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
