The Zyxel GS1915 series two 8-port GbE Smart Managed Layer 2 switches with and without PoE connectivity to the small business network. The GS1915 series supports NebulaFlex which comes with useful features and superior performance. This series is the most cost-effective cloud switch solution for the SB/SMB market. It can be easily configured through Nebula Control Center for unified cloud-based management.
Robust performance
With a switching capacity of 16 Gbps and forwarding performance of 11.9 Mbps, the Zyxel GS1915-8 ensures efficient handling of data across the network, making it ideal for businesses requiring high-speed connectivity. -
Comprehensive network standards support
This switch supports a wide range of networking standards, including IEEE 802.1D/Q/ab/p/w/x/3/3ab/3ad (LACP)/3az/3u/3x, ensuring broad compatibility and integration with existing network infrastructure. -
Advanced security features
Equipped with RADIUS authentication, SSL encryption, MAC address filtering, and more, the Zyxel GS1915-8 provides a secure networking environment to protect sensitive data from unauthorized access. -
Efficient network management
Manageable via SNMP and RMON, and featuring Quality of Service (QoS) for traffic prioritization, the switch offers comprehensive tools for network administration, ensuring optimal performance and reliability. -
Environmentally friendly design
The fanless design not only ensures silent operation but also reduces energy consumption, making the Zyxel GS1915-8 an eco-friendly choice for your networking needs.
- Zyxel GS1915 Series GS1915-8 - switch - managed - 8 ports - smart
- Switch - 8 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mbps
- Capacity
- Packet buffer size: 525000
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, RSTP, STP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, SSH-2, ICMP, Syslog
- Flow control, IGMP snooping, Syslog support, port mirroring, WRR queuing, MAC address filtering, IPv6 support, firmware upgradable, WFQ, STP support, RSTP support, DHCP snooping, QoS, fanless, LACP support, LLDP support, Port Security, DHCP client, SPQ, port isolation, CoS, DSCP support, Storm Control, ICMP, rate limit, DLF, schedule PoE, Loop Guard, Voice VLAN, LLDP-MED, VLAN trunking, MAC freeze, NTP support, MIB support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 100-240 V (50/60 Hz)
- 25 cm x 10.4 cm x 2.7 cm
- 620 g
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS
- Status Indicators
- Power, system, link/activity, cloud
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- Included Accessories
- Wall mounting kit
- MTBF
- 1,144,461 hours
- EMC, FCC, RoHS, BSMI CNS 13438, LVD, RCM, BSMI CNS 14336-1, EN 62368-1
- Localisation
- United Kingdom
- 25 cm
- 10.4 cm
- 2.7 cm
- 620 g
- Shipping Width
- 30.2 cm
- Shipping Depth
- 22.7 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 1.1 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
