Compact and Affordable Cloud-based Switch Series
The GS1915 Series includes four 8/24-port switches, with or without PoE options. The two PoE models facilitate wide variety of network setups with flexible PoE budget of both 60 W (8EP) and 130 W (24EP) with all PoE ports supporting IEEE 802.3at PoE+. This Series Switches come with useful features and superior performance just with plug-n-play.
Nebula, The Intelligent Cloud Management
The GS1915 Series supports free Nebula cloud management. Nebula provides both intuitive web interface and mobile App to deliver a streamlined experience for installation and management of your network, without additional cost for a software or hardware controller. Typical standalone mode is still available for your preference.
Nebula supports a comprehensive range of products from switch, AP, security firewall, to 5G/LTE mobile routers. Bringing you an easy and unified network experience.
Power Devices in Your Network Easily
GS1915-8EP and GS1915-24EP support 60W and 130W power budget respectively, ideal for setup just a few more AP and Camera for homes and small businesses. With Nebula App, it’s easy to reset an abnormal camera by power cycling it, even when you’re away.
- Zyxel GS1915 Series GS1915-24EP - switch - NebulaFLEX compatible - 24 ports - smart
- Switch - 24 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (12 PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 130 W
- Performance
- Switching capacity: 48 Gbps , Forwarding performance: 35.7 Mpps
- Capacity
- Packet buffer size: 525000
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMP, IGMPv2, IGMPv3, STP, RSTP
- Remote Management Protocol
- SSH-2, SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2, RMON 3, RMON 9, ICMP, Syslog
- Fanless, flow control, STP support, RSTP support, Loop Guard, VLAN trunking, Voice VLAN, MAC address filtering, port isolation, Port Security, MAC freeze, DHCP snooping, SPQ, WRR queuing, WFQ, Storm Control, DLF, DSCP support, Syslog support, DHCP client, NTP support, port mirroring, schedule PoE, IGMP snooping, IPv6 support, firmware upgradable, QoS, LLDP support, LLDP-MED, CoS, ICMP, rate limit, LACP support, MIB support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3af, IEEE 802.3at, IEEE 802.3az, IEEE 802.1p, IEEE 802.1D, IEEE 802.1w, IEEE 802.3ad (LACP), IEEE 802.1Q, IEEE 802.1ab (LLDP)
- Power
- AC 100-240 V (50/60 Hz)
- 33 cm x 23 cm x 4.4 cm
- 2.48 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 130 W
- Performance
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS
- 12 x 1000Base-T RJ-45 PoE+ , 12 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- 166.1 Watt
- Included Accessories
- Rack mount kit
- MTBF
- 768,989 hours
- FCC, RCM, BSMI CNS 13438, LVD, EN 62368-1, BSMI CNS 14336-1, RoHS, EMC
- 33 cm
- 23 cm
- 4.4 cm
- 2.48 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
