Ideal for small businesses that want to separate traffic on their growing network but don’t have a team of IT experts on hand, the Zyxel GS1900-48 48-port Gigabit Easy Smart Managed Switch delivers advanced features for more flexibility and control. With built-in support for VLANs, enhanced Quality of Service (QoS), IGMP Snooping, Link Aggregation (LAG), IPv6 and DoS prevention, this switch helps you easily isolate and prioritize wired and wireless traffic, while enabling guest network access and controlling bandwidth between ports. It’s all done through a user-friendly set-up wizard that makes setup and management a breeze.
Robust security
Equipped with RADIUS and TACACS+ authentication methods alongside SSL encryption, this switch ensures secure network access and data transmission. -
High reliability
With a mean time between failures (MTBF) of 229,313 hours, this device promises exceptional reliability and longevity for any business infrastructure. -
Efficient management
Supports a wide range of remote management protocols including SNMP, RMON, and Syslog, enabling efficient network management and monitoring. -
Advanced networking features
Features such as Energy-Efficient Ethernet (EEE), IGMP snooping, and port security provide enhanced network efficiency, multicast traffic management, and secure access. -
Flexible connectivity
Offers 48 RJ-45 ports for 1000Base-T connections and 2 SFP slots for Gigabit LAN uplinks, accommodating a wide variety of network layouts and expansions.
 - Zyxel GS1900 Series GS1900-48 - switch - managed - 48 ports - smart - rack-mountable
 - Switch - 48 ports - smart
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 48 x 10/100/1000 + 2 x Gigabit SFP (uplink)
- Performance
 - Switching capacity: 100 Gbps , Forwarding performance: 74 Mpps
- Capacity
 - Packet buffer size: 525000
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 9KB
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3, MSTP, RSTP, STP
- Remote Management Protocol
 - SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, ICMP, Syslog
 - Flow control, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, MAC address filtering, Port Security, DHCP client, SPQ, Storm Control, MIB II, dual image support, Voice VLAN, LLDP-MED, Guest VLAN, EEE, WRR, priority mapping, NTP support, TOS Precedence, port rate limiting
 - IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
 - AC 100-240 V (50/60 Hz)
 - 44 cm x 20 cm x 4.4 cm
 - 2.9 kg
- Localisation
 - United Kingdom
 - Limited lifetime warranty
- Designed For
 - Zyxel SFP-1000T, SFP-BX1310-10-D, SFP-BX1310-E, SFP-BX1490-10-D, SFP-BX1550-E, SFP-LHX1310-40-D, SFP-LX-10-D, SFP-LX-10-E, SFP-SX-D, SFP-SX-E, SFP-ZX-80-D
- Enclosure Type
 - Desktop, rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
- Performance
- Capacity
 - 8K entries
 - 9KB
- Routing Protocol
- Encryption Algorithm
 - SSL
- Authentication Method
 - RADIUS, TACACS+
- Status Indicators
 - Power, system, link/activity
 - 48 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP uplink
- Power Device
 - Internal power supply
- Voltage Required
- Included Accessories
 - Power cord
- Rack Mounting Kit
 - Included
- MTBF
 - 229,313 hours
 - FCC Class A certified, RoHS, CNS 13438, CNS 14336-1, EN 62368-1, RCM Class A
- Localisation
 - United Kingdom
 - 44 cm
 - 20 cm
 - 4.4 cm
 - 2.9 kg
- Shipping Width
 - 50.9 cm
- Shipping Depth
 - 29.2 cm
- Shipping Height
 - 9.3 cm
- Shipping Weight
 - 4.3 kg
 - Limited warranty - lifetime
 - 0 °C
 - 50 °C
 - 10 - 95% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
- Designed For
