Zyxel GS1900-24HP v2, 24-port GbE L2 PoE Smart Switch
Quicklinx: HHYLWS00 Mfr#: GS190024HPV2-GB0101F
12 In Stock
£221.04 ex VAT
£265.24 inc VAT
The ZyXEL GS1900 series of 24-port GbE Smart Managed Switch with Gigabit speed and essential managing functions bring your business network more fexibility and connectivity. Providing GbE switches with powersaving functions and full IPv6 support ensure your network to be ready for future expansions. In addition, the PoE models GS1900-24HP Gigabit switch complies with the IEEE 802.3at Power over Ethernet (PoE) Plus standard. The complete GS1900 series has been designed with useful features and advanced performances that empower your networks with speed and security.
The complete ZyXEL GS1900 series has an essential portfolio of 24-port compact desktop and rackmount size with GbE connectivity. Support multiple deployment methods to fulfill the needs for small offices and meeting room environments such as wall-, under table- or desktop-mounting and rackmount options. It's now quick and effortless to enjoy the high-speed business network applications without a hitch. Additionally, the GS1900-24HP is equipped with 2 extra SFP slots to provide 100M and GbE speeds for long-distance deployments.
  • Simple, Fast and Smart Managed Switches for small business connectivity
    The ZyXEL GS1900 series of 24-port GbE Smart Managed Switch with Gigabit speed and essential managing functions bring your business network more flexibility and connectivity. Providing GbE switches with powersaving functions and full IPv6 support ensure your network to be ready for future expansions. In addition, the PoE models GS1900-24HP Gigabit switch complies with the IEEE 802.3at Power over Ethernet (PoE) Plus standard. The complete GS1900 series has been designed with useful features and advanced performances that empower your networks with speed and security.
  • Versatility and fexibility for different needs
  • Simple, intuitive wizard set up
    For small businesses that want to manage their infrastructure in advance, the ZyXEL GS1900 series comes with a friendly built-in Web-based browser for simple configuration and management. Moreover, the friendly step-by-step intuitive wizard helps avoiding multiple complicated configuration pages for quick set up with few clicks in the matter of minutes.
  • Avoiding network errors with easy management
    The ZyXEL GS1900 series is equipped with advanced management features to make the network stable and secure: loop protection that prevents network flooding, dual images to provide a backup FW if one crashes and storm control to ensure network efficiency, friendly on/off DoS with simple click to enable/disable instead of several setup pages, while SSL ensures the management frames are well encrypted when the device is accessed. The GS1900 series provides network error prevention features and integrated network security for reduced risk and improved data streaming.
  • Energy saving for IEEE 802.3az
    As operating overheads such as electric bills increase constantly due to the arising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) and more ZyXEL innovative green features of ZyXEL GS1900 series can reduce energy consumption of Ethernet devices through multiple intelligent ways.
  • Traffic detection - Energy Efficient Ethernet (EEE) compliance
    The IEEE 802.3az Energy Efficient Ethernet (EEE) feature automatically detects network traffic and adjusts power consumption dynamically, as such the switch can reduce power consumption during low link utilization periods.
  • Inactive link detection
    The inactive link detection function automatically reduces power usage when inactive links or devices are detected. The ZyXEL GS1900 series can adjust power consumption according to the link status and number of the active network devices.
  • Cable length detection
    This green feature enables the switch to automatically detect the length of connected Ethernet cables and adjust power usage accordingly. The shorter the cable length, the less power it consumes.
  • Intelligence to power more devices
    ZyXEL's Intelligent PoE feature provides two PoE supply modes: classification mode and consumption mode. Especially in consumption mode, the GS1900-24HP reserves the actual required power automatically, and you can set power feeding priorities on different ports to get the optimized use of power resource. This capability increases the number of devices connected and deliver a better ROI for the business. Besides, the GS1900-24HP provides 170 watts of total budget power for devices with higher power requirements such as IP phones, IP cameras and wireless access points.
Zyxel GS1900-24HPv2 - switch - 26 ports - smart - rack-mountable
Switch - 26 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
170 W
Performance
Switching capacity: 52 Gbps , Forwarding performance: 39 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, Weighted Round Robin (WRR) queuing, store and forward, IPv6 support, Quality of Service (QoS), fanless, LACP support, LLDP support, Port Security, Energy Efficient Ethernet, Management Information Base (MIB), Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, per port bandwidth control, 525KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44.1 cm x 27 cm x 4.4 cm
3.55 kg
Enclosure Type
Rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
170 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, system, link/activity
24 x 1000Base-T RJ-45 PoE , 2 x Gigabit LAN SFP
Internal power supply
Rack Mounting Kit
Included
MTBF
879 243 hours
FCC Class B certified, C-Tick Class B, RoHS, EN 60950-1, BSMI CNS 13438, BSMI CNS 14336
44.1 cm
27 cm
4.4 cm
3.55 kg
Shipping Width
62.2 cm
Shipping Depth
35.8 cm
Shipping Height
10.8 cm
Shipping Weight
5.04 kg
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Brand: Zyxel
