Zyxel GS1900-24EP 24PORT GB Switch
Quicklinx: GR84WS00 Mfr#: GS1900-24EP-GB0101F
£188.47 ex VAT
£226.16 inc VAT
The GS1900 series includes both fan-less and built-in smart fan models. The smart fan is designed to automatically adjust speed based on device temperature. You can barely hear the sound while the switch is operating. It is ideal for your office environment.
It comes with default PoE consumption mode which delivers only the actual power required by your networked devices, reserves the rest, and optimizes its power budget. That means a single switch can power more APs, IP cameras, and VoIP phones, ensuring a better ROI for your business. All of them support the IEEE 802.3at providing a maximum of 30W per port.
The GS1900 is a series of switches with full non-blocking bandwidth. An ideal upgrade from an unmanaged switch, it's a great choice for SMBs that want to enjoy high-speed business network applications at full wired non-blocking speed.
The smart managed GS1900 series switch feature with a web-based interface to manage advanced functions such as VLAN, QoS, IGMP snooping, link aggregation, IPv6, and Dos prevention easily. Also, the user-friendly wizard helps to walk through setup, configuration, and even advanced settings quickly.
  • Near silent operation
  • Intelligent PoE+ powers more devices
  • Speedy Gigabit performance - built for SMBs
  • Easy and intuitive management
    The smart managed GS1900 series switch feature with a web-based interface to manage advanced functions such as VLAN, QoS, IGMP snooping, link aggregation, IPv6, and DoS prevention easily. Also, the user-friendly wizard helps to walk through setup, configuration, and even advanced settings quickly.
Zyxel GS1900-24EP - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (12 PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 48 Gbps , Forwarding performance: 35.7 Mpps , Packet buffer size: 525 KB
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, NTP, ICMP, DHCP, IPv6, RSTP, TACACS+, RADIUS
Flow control, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, store and forward, MAC address filtering, IPv6 support, half duplex mode, full duplex mode, firmware upgradable, QoS, LACP support, LLDP support, Port Security, DHCP client, dual firmware images, SPQ, NDP, CoS, ToS, Storm Control, MIB II, schedule PoE, Voice VLAN, LLDP-MED, Guest VLAN, EEE, WRR, VLAN Tagging, priority mapping, LAG
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
33 cm x 23 cm x 4.4 cm
2.48 kg
Enclosure Type
Rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Status
12 x 1000Base-T RJ-45 , 12 x 1000Base-T RJ-45 PoE+
Internal power supply
166.5 Watt
Rack Mounting Kit
Included
MTBF
910,015 hours
C-Tick, BSMI, CB, FCC, RoHS, IEC 60950-1, EN 60950-1, LVD, CNS 13438, CNS 14336-1
33 cm
23 cm
4.4 cm
2.48 kg
Shipping Width
38.9 cm
Shipping Depth
33.7 cm
Shipping Height
7.9 cm
Shipping Weight
3.87 kg
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Brand: Zyxel
