Zyxel GS1900-10HP v2, 8-port GbE L2 PoE Smart Switch
Quicklinx: HHYKWS00 Mfr#: GS1900-10HP-GB0102F
£86.33 ex VAT
£103.59 inc VAT
The ZyXEL GS1900 series with Gigabit speed and essential managing functions bring your business network more flexibility and connectivity. The 1900 series GbE switches with power-saving functions and fanless design ensure your network to be ready challenges. They have been designed with useful features and advanced performances that empower your networks with speed and security as well as silent operation in your office environments.
  • Versatility and flexibility for different needs
    The complete ZyXEL GS1900 series combines compact desktop and rackmount size with GbE connectivity. All models support multiple deployment methods to fulfill the needs for small offices and meeting room environments. It's quick and effortless to enjoy the highspeed business network applications without a hitch. The series is also ideal for connecting numerous powered devices to form a flawless business network.
  • Simple, intuitive setup
    For small businesses that want to manage their infrastructure in advance, the ZyXEL GS1900 series comes with a friendly built-in web-based browser for simple configuration and management. Moreover, the friendly step-by-step intuitive wizard helps avoiding multiple complicated configuration pages for quick setup with few clicks in the matter of minutes. To guide the users from startup, VLAN, Guest VLAN to QoS setting, the ZyXEL series offers four most common steps and combines them into a quick and easy setup wizard; which does not just save deployment time and efforts, but is also helpful especially for the non-IT staff.
  • Avoiding network errors with easy management
    The ZyXEL GS1900 series is equipped with advanced management features to make the network stable and secure: loop protection that prevents network flooding, dual images to provide a backup FW if one crashes and storm control to ensure network efficiency, friendly on / off DoS with simple click to enable / disable instead of several setup pages, while SSL ensures the management frames are well encrypted when the device is accessed. The GS1900 series provides network error prevention features and integrated network security for reduced risk and improved data streaming.
Zyxel GS1900-10HP - switch - 26 ports - smart - rack-mountable
Switch - 26 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
+ 2
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
+ 2
Internal power supply
Rack Mounting Kit
Included
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Brand: Zyxel
