Zyxel GS1350-6HP, 6 Port Managed CCTV PoE Switch
Quicklinx: HHYJWS00 Mfr#: GS1350-6HP-GB0101F
20 In Stock
£103.42 ex VAT
£124.10 inc VAT
The GS1350 excels with an eye-catching identity dedicated for surveillance switch.
  • Easy for long-distance deployment
    Traditionally, PoE switch delivers power and data within the distance of the 100 meter limitation. The GS1350 series fulfills the need to deploy IP camera or power devices using existing Cat 5e cable to distant locations. By enabling extended-range mode, instantly achieve distant deployments up to 250 m.
  • High power budget, intuitive front panel design
    The intuitive LED indicator on the front panel allows inspecting real-time PoE status.
Zyxel GS1350-6HP - switch - 6 ports - smart
Switch - 6 ports - smart
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (PoE+) + 1 x Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 12 Gbps , Forwarding rate: 8.9 Mpps
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH-2, CLI, NTP, ICMP
Flow control, VLAN support, IGMP snooping, Syslog support, port mirroring, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, WFQ, STP support, RSTP support, DHCP snooping, QoS, fanless, DHCP relay, SNMP trap, DHCP client, Energy Efficient Ethernet, SPQ, NDP, port isolation, CoS, IGMP proxy, security lock slot (cable lock sold separately), 8KV/15KV ESD Protector, 525KB packet buffer, DSCP support, IGMP filtering, IGMP throttling, CPU protection, 4KV Surge protection, dual image support, DLF, IGMP querier, schedule PoE, Loop Guard, Voice VLAN, LLDP-MED, WRR, MAC based VLAN, port-based VLAN, Unknown Storm Control, VLAN trunking, IPv4 and IPv6 dual stack
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3bt
19.3 cm x 8.4 cm x 2.6 cm
410 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
250 W
Performance
8K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, PoE, link/activity, locator, cloud
5 x Gigabit LAN RJ-45 3 ports (PoE+) / 2 ports (PoE) - 60 W , 1 x Gigabit LAN SFP uplink
External power adapter
Power Provided
DC 52 - 57 V
Wall mounting kit
MTBF
2,021,885.87 hours
FCC Class A certified, EMC, RoHS, BSMI CNS 13438, C-Tick Class A, LVD, BSMI CNS 14336-1, EN 62368-1
United Kingdom
Software Included
Zyxel One Network Utility
19.3 cm
8.4 cm
2.6 cm
410 g
Shipping Width
24.2 cm
Shipping Depth
25.5 cm
Shipping Height
6.5 cm
Shipping Weight
1.08 kg
Limited warranty - lifetime
-20 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
