Zyxel GS1350-26HP, 26 Port Managed CCTV PoE Switch
Quicklinx: HHYHWS00 Mfr#: GS1350-26HP-GB0101F
10 In Stock
£287.04 ex VAT
£344.44 inc VAT
Traditionally, PoE switch delivers power and data within the distance of the 100 meter limitation. The GS1350 series fulfills the need to deploy IP camera or power devices using existing Cat 5e cable to distant locations. By enabling extended-range mode, instantly achieve distant deployments up to 250m. Save your money and effort with simply one PoE.
The GS1350 series includes four models with large power budgets of up to 375 W accommodating the requirement for powering up multiple IP cameras. The intuitive LED indicator on the front panel allows inspecting real-time PoE status. In addition, the one-touch "Restore" button on GS1350 Series helps effortless recovery from misconfigurations.
  • New outlook
    Coated in titanium gray, the GS1350 excels with an eye-catching identity dedicated for surveillance Switch.
  • Easy for long-distance deployment
  • High power budget, intuitive front panel design
Zyxel GS1350-26HP - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 52 Gbps , Forwarding rate: 38.7 Mpps , Packet buffer size: 525 KB
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH-2, CLI, NTP, ICMP, DHCP, RSTP, RADIUS
Flow control, IGMP snooping, Syslog support, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, WFQ, DHCP snooping, LLDP support, DHCP relay, LACP, DHCP client, MIB, dual firmware images, SPQ, NDP, port isolation, CoS, 8KV/15KV ESD Protector, DSCP support, IGMP filtering, CPU protection, 4KV Surge protection, Loop Guard, LLDP-MED, EEE, WRR, VLAN trunking, security slot (Kensington security lock compatible)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44.1 cm x 27 cm x 4.4 cm
3.58 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
8K entries
Routing Protocol
Encryption Algorithm
SSL, SHA-2
Authentication Method
RADIUS, Secure Shell v.2 (SSH2)
24 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T / 1000Base-X RJ-45/SFP uplink
Internal power supply
448.9 Watt
Rack Mounting Kit
Included
MTBF
888,495 hours
FCC, RoHS, BSMI CNS 13438, C-Tick Class A, LVD, BSMI CNS 14336-1, EN 62368-1
United Kingdom
44.1 cm
27 cm
4.4 cm
3.58 kg
-20 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
