Zyxel GS1350-18HP, 18 Port Managed CCTV PoE Switch
Quicklinx: HHYGWS00 Mfr#: GS1350-18HP-GB0101F
£228.92 ex VAT
£274.70 inc VAT
Traditionally, PoE switch delivers power and data within the distance of the 100 meter limitation. The GS1350 series fulfills the need to deploy IP camera or power devices using existing Cat 5e cable to distant locations. By enabling extended-range mode, instantly achieve distant deployments up to 250m. Save your money and effort with simply one PoE.
The GS1350 series includes four models with large power budgets of up to 375 W accommodating the requirement for powering up multiple IP cameras. The intuitive LED indicator on the front panel allows inspecting real-time PoE status. In addition, the one-touch "Restore" button on GS1350 Series helps effortless recovery from misconfigurations.
  • New outlook
    Coated in titanium gray, the GS1350 excels with an eye-catching identity dedicated for surveillance Switch.
  • Easy for long-distance deployment
  • High power budget, intuitive front panel design
Zyxel GS1350-18HP - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+) + 2 x combo Gigabit Ethernet/Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 36 Gbps , Forwarding rate: 26.7 Mpps , Packet buffer size: 525 KB
VLANs supported: 256
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH-2, CLI, NTP, ICMP
Flow control, VLAN support, IGMP snooping, Syslog support, port mirroring, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, WFQ, STP support, RSTP support, DHCP snooping, QoS, DHCP relay, SNMP trap, DHCP client, Energy Efficient Ethernet, SPQ, NDP, port isolation, CoS, IGMP proxy, security lock slot (cable lock sold separately), 8KV/15KV ESD Protector, DSCP support, IGMP filtering, IGMP throttling, CPU protection, 4KV Surge protection, dual image support, DLF, IGMP querier, schedule PoE, Loop Guard, Voice VLAN, LLDP-MED, WRR, MAC based VLAN, port-based VLAN, Unknown Storm Control, VLAN trunking, IPv4 and IPv6 dual stack
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
33 cm x 23 cm x 4.4 cm
2.42 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
250 W
Performance
8K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, PoE, link/activity, locator, cloud
16 x Gigabit LAN RJ-45 PoE+ - 30 W , 2 x Gigabit LAN RJ-45/SFP uplink
Internal power supply
Rack Mounting Kit
Included
MTBF
1,699,692.18 hours
FCC Class A certified, EMC, RoHS, BSMI CNS 13438, C-Tick Class A, LVD, BSMI CNS 14336-1, EN 62368-1
United Kingdom
Software Included
Zyxel One Network Utility
33 cm
23 cm
4.4 cm
2.42 kg
Shipping Width
39.1 cm
Shipping Depth
33.8 cm
Shipping Height
8 cm
Shipping Weight
3.31 kg
Limited warranty - lifetime
-20 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
