ZyXEL's GS-108B 10/100/1000 Mbps desktop switch is designed for reliable high-performance networks. Thanks to the non-blocking switching fabric in full-duplex mode, the maximum speed can reach up to 2000 Mbps per port; the store-and-forward service brings low-latency and error-free packet delivery. With these features, the transmission efficiency can be boosted dramatically.
With the N-way auto-negotiation function, the GS-108B automatically connects to its network counterparts with the highest possible network speed and activates duplex mode automatically. All it takes to enliven your network is just plugging in the cable, and no manual configuration is required.
The stylish compact metal housing fits any working environment. GS-108B comes with different port configurations for affordable and reliable SOHO network expansion needs.
 - Zyxel GS-108B - v3 - switch - 8 ports - unmanaged
 - Switch - 8 ports - unmanaged
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
 - Switching fabric bandwidth: 16 Gbps
- MAC Address Table Size
 - 8K entries
- Jumbo Frame Support
 - 9KB
 - Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Quality of Service (QoS), 128KB packet buffer, Energy Efficient Ethernet, loop prevention
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
 - AC 120/230 V
 - 15.5 cm x 8.5 cm x 2.6 cm
 - 325 g
- Localisation
 - United Kingdom
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000
- Performance
 - 8K entries
 - 9KB
- Status Indicators
 - Power, link/activity
 - 2 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 4 x 1000Base-T RJ-45
- Power Device
 - External power adapter
- Voltage Required
 - AC 120/230 V
 - 3 Watt
 - FCC Class B certified, BSMI
- Localisation
 - United Kingdom
 - 15.5 cm
 - 8.5 cm
 - 2.6 cm
 - 325 g
 - 0 °C
 - 50 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 10 - 95% (non-condensing)
