Zyxel GS-108B V3 8-Port Desktop Gigabit Ethernet Switch
Quicklinx: BW3CWS00 Mfr#: GS-108BV3-GB0101F
13 In Stock
£14.64 ex VAT
£17.56 inc VAT
ZyXEL's GS-108B 10/100/1000 Mbps desktop switch is designed for reliable high-performance networks. Thanks to the non-blocking switching fabric in full-duplex mode, the maximum speed can reach up to 2000 Mbps per port; the store-and-forward service brings low-latency and error-free packet delivery. With these features, the transmission efficiency can be boosted dramatically.
With the N-way auto-negotiation function, the GS-108B automatically connects to its network counterparts with the highest possible network speed and activates duplex mode automatically. All it takes to enliven your network is just plugging in the cable, and no manual configuration is required.
The stylish compact metal housing fits any working environment. GS-108B comes with different port configurations for affordable and reliable SOHO network expansion needs.
Zyxel GS-108B - v3 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching fabric bandwidth: 16 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Quality of Service (QoS), 128KB packet buffer, Energy Efficient Ethernet, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 120/230 V
15.5 cm x 8.5 cm x 2.6 cm
325 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Power, link/activity
2 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 4 x 1000Base-T RJ-45
External power adapter
AC 120/230 V
3 Watt
FCC Class B certified, BSMI
United Kingdom
15.5 cm
8.5 cm
2.6 cm
325 g
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
Brand: Zyxel
