Zyxel GS-105SV2-GB0101F 5-Port Gigabit Ethernet Media Switch
Quicklinx: 9Q98WS00 Mfr#: GS-105SV2-GB0101F
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
Hurry, only 1 left in stock!
£12.14 ex VAT
£14.56 inc VAT
High-performance Gigabit for Optimized Video and Online Gaming Experience
The ZyXEL GS-105S v2 5-Port Desktop Gigabit Ethernet Media Switch can easily connect multiple media devices to home networks at blazing-fast Gigabit simultaneously. Moreover, the newly designed GS-105S v2 allow smooth video streaming and online gaming activities.
Plug-and-play, stylish design
With the easy plug-and-play features, you can connect the ZyXEL GS-105S v2 to VoIP, media players, game consoles, TV set-top box or Web browsing devices to your home network without any configuration effort. The stylish modern look and streamlined design also make the GS-105S v2 fits nicely in the house.
Bi-color LED indicators for Ethernet port status
The ZyXEL GS-105S v2 features auto-sensing function and front Gigabit Ethernet ports with easy-to-understand LED indicators, which allows users to quickly check link and activity status at a glance.
Blazing-fast Gigabit data transmission
The ZyXEL GS-105S v2 10/100/1000 Mbps switch is designed to provide reliable high-performance media network connectivity 10 times faster than Fast Ethernet. It perfectly fulfills the demands for multimedia streaming and online gaming at the same time.
  • Plug-and-play, stylish design
  • Bi-color LED indicators for Ethernet port status
  • Blazing-fast Gigabit data transmission
Zyxel GS-105S v2 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Switching fabric bandwidth: 10 Gbps
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, half duplex mode, full duplex mode, Quality of Service (QoS), 128KB packet buffer, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 120/230 V
10.6 cm x 7.5 cm x 3.2 cm
105 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Status Indicators
Power, link/activity
1 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 2 x 1000Base-T RJ-45 low priority
External power adapter
AC 120/230 V
2.5 Watt
Plug and Play, FCC Class B certified, BSMI
United Kingdom
10.6 cm
7.5 cm
3.2 cm
105 g
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 5
Managed: No
POE: No
Brand: Zyxel
Price Range Ex VAT: 0 - 50
