The USG20-VPN provides safe and reliable VPN connections. Faster processors have vastly boosted the capabilities of attackers to decrypt VPN tunnels. With support to the advanced Secure Hash Algorithm 2, the VPN firewall provides safe VPN connections to ensure maximum security for business communications.
Safer, more reliable VPN connections
Faster processors have vastly boosted the capabilities of attackers to decrypt VPN tunnels. With support to the advanced Secure Hash Algorithm 2, the VPN firewall provides safe VPN connections to ensure maximum security for business communications. -
Business mobility
To support dynamic, mobile business operations in BYOD business environments, the VPN firewalls offer business mobility with Layer-2 Tunneling Protocol VPN for mobile devices. The VPN firewall supports L2TP VPN on a wide variety of mobile Internet devices.
- Zyxel USG20-VPN - firewall
- Firewall
- Form Factor
- External
- Localisation
- Europe
- Data Link Protocol
- Performance
- Firewall throughput: 350 Mbps , VPN throughput: 90 Mbps
- Capacity
- User licences: unlimited , Concurrent IPSec VPN tunnels: 10 , Concurrent sessions: 20000 , Concurrent SSL VPN users: 1 , SSL VPN users: 5
- VoIP Protocols
- H.323, SIP
- 21.6 cm x 14.3 cm x 3.3 cm
- 1.04 kg
- Firewall
- 21.6 cm
- 14.3 cm
- 3.3 cm
- 1.04 kg
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wired
- L2TP, IPSec, PPPoE, DNS, DDNS
- Routing Protocol
- OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- Performance
- Capacity
- Routing, VPN support, PAT support, SNAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, ALG support, manageable, stackable, E-mail alert, IPv6 support, High Availability, Transparency, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, DHCP relay, DHCP client, dual firmware images, tagged VLAN, Generic Routing Encapsulation (GRE), VPN auto-reconnection, Single Sign-On (SSO) support, ZyXEL One Network (ZON), SmartConnect Technology, failover protection
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
- Authentication Method
- RADIUS, X.509 certificates, LDAP, XAUTH authentication
- IEEE 802.1Q, X.509
IP Telephony
- VoIP Protocols
- H.323, SIP
- 4 x 1000Base-T - RJ-45 (LAN / DMZ) , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB - Type A , 1 x - SFP (mini-GBIC) , 1 x console - RJ-45
- Cables Included
- 1 x console cable
- MTBF
- 44,000 hour(s)
- UL, BSMI, ICSA Firewall certified, FCC Part 15 B, IC, EMC Class B, RCM
- Power Device
- External power adapter
- 12 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
