ZyAIR's extended reach antennas allow users to get the best wireless performance out of the most difficult environments. With ZyAIR antennas, customers will enjoy greater reach and better transmission quality for their wireless networks.
This 6dBi Directional Antenna is ideal for extending the coverage of an Access Point in one direction, such as down a corridor. This Antenna has 70 deg coverage in both horizonal and vertical planes. Supplied with a 1.5m Cable and an SMA connector.
- Focus Coverage.
- Wall mounted.
- Zyxel ZyAIR EXT 106 - antenna
- Product Type
- Antenna
- 8.6 cm x 7.6 cm x 11.8 cm
- 110 g
- Aerial Placing / Mounting
- Wall-mountable
- Gain
- 6 dBi
- Directivity
- Directional
- 2-year warranty
- Designed For
- ZyAIR B-1000, B-1000v2, B-101, B-2000, B-2000v2, B-3000
- Product Type
- Antenna
- 8.6 cm
- 7.6 cm
- 11.8 cm
- 110 g
Aerial
- Wall-mountable
- Gain
- 6 dBi
- Directivity
- Directional
Cabling & Wiring
- Connector Provided
- 1 x SMA
- Limited warranty - 2 years
- Designed For
- Zyxel ZyAIR B-1000, B-1000v2, B-101, B-2000, B-2000v2, B-3000
