Zyxel Armor Z1 Dual Band AC2350 Wireless Router
Quicklinx: BMYCWS00 Mfr#: NBG6816-EU0101F
Deploy a powerful wireless network that can deliver fast wireless data speeds for lag free online multiplayer gaming experience and smoothly stream high-definition videos with the ZyXEL Armor Z1, AC2350 Dual-Band Wireless Gigabit Router.
  • Blistering network speed
    Connect your 802.11ac wireless equipped devices to the ZyXEL Armor Z1 router and get up to Gigabit data transfer rate. Stream and watch movies in ultra-high-definition (UHD) quality without the pesky buffering stutter. Got fiber broadband connection? Download or upload digital contents wirelessly to the web faster.
  • Safe and scheduled web browsing
    Filter offensive online contents for a cleaner and safer web browsing experience. Manage and restrict individual devices online network times to avoid constant bandwidth consumption and data usage overage.
  • Bandwidth where it is needed with Smart QoS
    The ZyXEL Armor Z1 allocates the right amount of bandwidth to each networked devices automatically with its StreamBoost technology. Play an intense online multiplayer game, watch high-definition streaming movies, browse on your social network, download a large file, and do more all at the same time without experiencing any performance drop.
  • Effective wireless connection by Beamforming
    Instead of broadcasting signals everywhere in your home, ZyXEL Armor Z1 is equipped with Beamforming technology to focus and amplify its signal directly to your wireless connected device(s), allowing you to connect wirelessly online throughout your whole home.
Zyxel Armor Z1 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
IGMPv2, IGMP, static IP routing
Firewall protection, NAT support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), dynamic DNS server, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, DLNA Media Server, DHCP client, Denial of Service (DoS), StreamBoost, PPTP passthrough, L2TP passthrough
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
29.77 cm x 20.78 cm x 7.15 cm
840 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
PPPoE, DHCP
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac, FCC, LVD
1 x 1.4 GHz
RAM
512 MB
Flash Memory
4 GB
Status Indicators
Power, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
29 Watt
1 x network cable
Europe
29.77 cm
20.78 cm
7.15 cm
840 g
10 - 90% (non-condensing)
