Deploy a powerful wireless network that can deliver fast wireless data speeds for lag free online multiplayer gaming experience and smoothly stream high-definition videos with the ZyXEL Armor Z1, AC2350 Dual-Band Wireless Gigabit Router.
Blistering network speed
Connect your 802.11ac wireless equipped devices to the ZyXEL Armor Z1 router and get up to Gigabit data transfer rate. Stream and watch movies in ultra-high-definition (UHD) quality without the pesky buffering stutter. Got fiber broadband connection? Download or upload digital contents wirelessly to the web faster. -
Safe and scheduled web browsing
Filter offensive online contents for a cleaner and safer web browsing experience. Manage and restrict individual devices online network times to avoid constant bandwidth consumption and data usage overage. -
Bandwidth where it is needed with Smart QoS
The ZyXEL Armor Z1 allocates the right amount of bandwidth to each networked devices automatically with its StreamBoost technology. Play an intense online multiplayer game, watch high-definition streaming movies, browse on your social network, download a large file, and do more all at the same time without experiencing any performance drop. -
Effective wireless connection by Beamforming
Instead of broadcasting signals everywhere in your home, ZyXEL Armor Z1 is equipped with Beamforming technology to focus and amplify its signal directly to your wireless connected device(s), allowing you to connect wirelessly online throughout your whole home.
- Zyxel Armor Z1 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1733 Mbps
- PPPoE, DHCP
- Routing Protocol
- IGMPv2, IGMP, static IP routing
- Firewall protection, NAT support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), dynamic DNS server, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, DLNA Media Server, DHCP client, Denial of Service (DoS), StreamBoost, PPTP passthrough, L2TP passthrough
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- 29.77 cm x 20.78 cm x 7.15 cm
- 840 g
- Localisation
- Europe
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1733 Mbps
- PPPoE, DHCP
- Routing Protocol
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac, FCC, LVD
- Processor
- 1 x 1.4 GHz
- RAM
- 512 MB
- Flash Memory
- 4 GB
- Status Indicators
- Power, WPS, Internet
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 4
- Power Device
- External power adapter
- 29 Watt
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 29.77 cm
- 20.78 cm
- 7.15 cm
- 840 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
