Zyxel 8-port Gigabit Unmanaged PoE Switch
FREE 3 YEAR NBD REPLACEMENT WARRANTY
Quicklinx: 8MF2WS00 Mfr#: GS1100-8HP-GB0101F
The ZyXEL GS1100 series is the best solution for instant Gigabit connectivity in office environments demanding silent operation and better energy efficiency. With power-saving functions, Gigabit Ethernet and a fanless design, the GS1100 Series provides Plug-and-Play simplicity for high-bandwidth network applications. The GS1100-8HP is an 8-port Gigabit switch that complies with the IEEE 802.3at Power over Ethernet (PoE) plus standard, providing 4 PoE ports with up to 30 watts per port.
  • Green networking
    The GS1100 series not only offers Gigabit Ethernet connectivity for next-generation network applications, but also power-saving functions for better energy efficiency. Capable of dynamically adjusting power output according to traffic, active links and cable length, the GS1100 series can reduce energy consumption for lowered operating costs.
  • Fanless design
    The complete GS1100 series comes in a fanless design that ensures silent operation in small or quiet office environments. The GS1100-8HP PoE model is specifically designed with an external power adapter that eliminates the need for an additional fan to cool down the device, making it perfect for quiet PoE deployments.
  • Gigabit to the desktop
    The ZyXEL GS1100 series offers small offices 8 port Gigabit connectivity at the most competitive price. With Gigabit network performance and high cost-effectiveness, the GS1100 series is the ideal solution for bandwidth-intensive applications such as high-resolution photo transmission, video/audio streaming and server farm connections.
  • Freedom of installation via PoE
    The GS1100-8HP supports the IEEE 802.3at PoE plus standard to ease the installation of network devices in challenging spaces such as ceilings or walls. The power supply of up to 30 watts per port allows the GS1100-8HP to power PoE-enabled WLAN APs, VoIP phones and IP surveillance cameras through CAT-5 cables of less than 100 meters in length. With the ZyXEL GS1100-8HP, there is no need for extra power adapters in installing PoE devices in difficult locations. This feature helps enterprises reduce installation time and cost when there are many such devices on the network.
Zyxel GS1100-8HP - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 + 4 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
21 cm x 10.4 cm x 2.7 cm
540 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
Jumbo Frame Support
9000 bytes
Status Indicators
Port status, power, PoE, link/activity
4 x 1000Base-T RJ-45 PoE , 4 x 1000Base-T RJ-45
Power supply - external
90 Watt
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1
United Kingdom
21 cm
10.4 cm
2.7 cm
540 g
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
8MF2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
