Zyxel 6 Pack 802.11agn Dual-Radio Wireless Access Point
Quicklinx: 8MFPWS00 Mfr#: NWA5560-N-EU0201F
Within business today companies continually face the challenge of providing wireless access to guests and mobile employees without compromising security. To address this situation ZyXEL has developed the NWA5560N WLAN Access Point. The solution is designed to deliver high performance 11n wireless to provide seamless mobility in medium to large campus and secure distributed enterprise environments.
  • Central configuration
    This w secure WLAN solution is based on the ZyXEL NWA5560N managed access points that provides comprehensive wireless coverage.
  • Better wireless experience
    Central administration simplifies planning immensely. The managed access points are first installed at the most suitable locations for WLAN reception. Areas with insufficient coverage or too low data speeds can be made accessible with additional managed access points. The best results can be obtained however when a site survey is carried out enabling a simplified installation and better wireless experience.
  • Captive portal
    A captive portal intercepts all network traffic regardless of address or port until users authenticate their identity through a designated login web page. As an added security measure, the NXC contains captive portal functionality; this means that all web page requests can be initially redirected to a special web page that requires guests to authenticate their sessions.
Zyxel NWA-5560-N - radio access point - Wi-Fi
Radio access point
Packaged Quantity
6 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 140 Mbps
Power Over Ethernet (PoE) Supported
PoE
21.8 cm x 17.4 cm x 5.4 cm
1.36 kg
Packaged Quantity
Radio access point
21.8 cm
17.4 cm
5.4 cm
1.36 kg
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Remote Management Protocol
SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Auto-sensing per device, DHCP support, power over Ethernet (PoE), VLAN support, Wireless Distribution System (WDS) support, full duplex mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), 2T2R MIMO technology
Encryption Algorithm
WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Secure Shell (SSH)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
External detachable
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45
FCC Part 15 B, FCC Part 15.247, FCC Part 15 C, RoHS, EN 60950-1, FCC Part 15 E, EN 60601-1-2, DGT, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
PoE
External power adapter
10 - 90% (non-condensing)
