ZTE MF93D 4G Wireless Hotspot
Quicklinx: B2HRWS00 Mfr#: MF93D#BTBM
The ZTE MF93D, second generation ultra-speed 4G (LTE) uFi mobile hotspot device can reach a maximum speed of up to 100 Mbps and can be accessed by 10 users at the same time making it the ideal choice for global users looking to enjoy ultra-speed 4G network services.
Incorporating second generation Qualcomm LTE chips, the ZTE MF93D provides significant performance enhancements to ZTE's first generation LTE uFi products including decreased power consumption and improved heat dispersion. It supports dual-band 2.4 G/5 GHz Wi-Fi networks and mainstream 4G bands in the Europe and Asian-Pacific regions, and can also use 3G and 2G networks, eliminating the cost of upgrading terminals. It has increased battery capacity of 2800 mAh, guarantees that users can enjoy ultra-speed surfing on the Internet regardless of the time or place.
Users' mobile phones can be used to simply and quickly check the status of uFi devices, network signal strength, battery capacity, data flow statistics and upload/download speed.
ZTE MF93D - mobile hotspot - 4G LTE
Mobile hotspot - USB 2.0
External
Max Transfer Rate
100 Mbps
Mobile Communication Protocol
GSM, UMTS, HSDPA, HSPA, HSPA+, LTE
Mobile Band
GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / LTE 800/900/1800/2600
USB, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
2800 mAh - up to 9 hrs
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
10.7 cm x 6.08 cm x 1.6 cm
123 g
Mobile hotspot
External
Built-in Devices
1.44-inch OLED
Modem
Bus
USB 2.0
Wireless
Max Transfer Rate
100 Mbps
Mobile Band
Wireless
IPv6 support, 2T2R MIMO technology
DLNA CERTIFIED
Supported Flash Memory Cards
microSD, microSDHC
1 x USB 2.0 , 1 x aerial
SIM Card Supported
1
Lithium Ion
10.7 cm
6.08 cm
1.6 cm
123 g
