Enjoy eco-friendly computing with superior energy-efficiency and performance with the Zotac ZBOX ID41 Plus mini-PC powered by the class-leading Next-Generation Nvidia ION and Intel Atom architectures. Next-Generation Nvidia ION graphics deliver unrivaled levels of performance and high definition video decode capabilities to the Zotac ZBOX ID41 Plus mini-PC with Nvidia CUDA, PureVideo HD and HDMI 1.3a technologies for eco-friendly computing with premium audio and video capabilities.
High performance eco-friendly computing is only two thumb screws away with the Zotac ZBOX ID41 Plus mini-PC thanks to a user friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and 2 204-pin DDR3-800 Sodimm slots enables users to customize the internals of the Zotac ZBOX ID41 Plus to their own needs - a 250GB hard drive and 2GB of DDR3 module are included -- while USB 3.0 and USB 2.0 ports, a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) and eSATA port provide greater external expansion capabilities for perfect eco-friendly computing.
- NVIDIA PureVideo HD technology
- NVIDIA CUDA technology
- Adobe Flash Player 10.1 acceleration
- Microsoft DirectX 10.1 compatible
- 2 Years Warranty
- Model: Model ZOTAC ZBOX ID41 PLUS
- Chipset: Manufacturer Intel, Chipset NM10 Express, GPU Next-Generation Nvidia ION w/512MB DDR3
- CPU Compatibility: Name Intel Atom D525 (dual-core) (1.8 GHz), Socket NA (integrated CPU), Front-side bus 800 MHz
- Memory: Memory Type DDR3, Memory Speed 800 MHz, Slots 2 x 204-pin SODIMM, Capacity 2GB DDR3-800 (up to 4GB)
- Expansion: Expansion Slots NA
- 3D API: DirectX DirectX 10.1, OpenGL OpenGL 3.2
- Networking: Ethernet 10/100/1000 Mbps, WiFi 802.11n/g/b (300Mbps)
- Audio: Analog Stereo Output, Digital 8-ch via HDMI, S/PDIF
- Storage: Hard Drive 250GB 5400RPM HDD, Optical Drive NA, Memory Card Reader 6-in-1 (MMC/SD/SDHC/MS/MS Pro/xD)
- Ports: DVI 1 (Dual-link) HDMI 1 (HDCP w/8-channel digital audio), VGA N/A, SATA 1 (SATA 3.0 Gbps), eSATA 1, IDE N/A, PS/2 N/A, Serial Port N/A, USB Ports 2 USB 3.0 (on back panel) 4 USB 2.0 (2 back panel, 1 front panel, 1 top panel), Firewire N/A
- Cooler: Cooler NA
- Form Factor: Form Factor N/A
- OS Compatibility, Windows User installed (Windows XP, Vista, 7 and Linux ready)
- General: SLI Supported No, Maximum Resolution N/A
- Other: Wake-On Support, Overclocking features
- Warranty: 2 Years
- ZOTAC Atom TFT
- System Type
- Netbook
- Built-in Devices
- Stereo speakers
- Processor
- Intel Atom
- Multi-Core Technology
- Dual-Core
- Chipset Type
- Intel NM10 Express
RAM
- Technology
- DDR3 SDRAM
Storage
- Hard Drive
- 250 GB
Card Reader
- Supported Flash Memory Cards
- MultiMediaCard
Audio
- Audio Output
- Sound card
- High Definition Audio
- Audio Input
- Microphone
- Networking
- Network adapter
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power Device
- External
Zotac Z-Box Plus Atom Dual Core 525 2GB 250GB Mini-PC (ZBOXHD-ID41-PLUS-B)
