Enjoy eco-friendly computing with superior energy-efficiency and performance with the ZOTAC ZBOX ID84 mini-PC powered by an NVIDIA® GeForce® GT 520M graphics processor and Intel® Atom™ processor. NVIDIA® GeForce® GT 520M graphics deliver unrivaled levels of performance and high definition video decode capabilities to the ZOTAC ZBOX ID84 mini-PC with NVIDIA® CUDA™, PureVideo™ HD and HDMI 1.4a technologies for eco-friendly computing with premium audio and video capabilities.
High performance eco-friendly computing is only two thumb screws away with the ZOTAC ZBOX ID84 mini-PC thanks to a user friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and 2 204-pin DDR3-1066 SO-DIMM slots enable users to customize the internals of the ZOTAC ZBOX ID84 to their own needs while USB 3.0 and USB 2.0 ports and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) and provide greater external expansion capabilities for perfect eco-friendly computing.
- Model ZBOX ID84
- Chipset: Manufacturer Intel®
- Chipset NM10
- GPU NVIDIA® GeForce® GT 520M
- CPU Compatibility: Intel® Atom™ D2550 (dual-core 1.86 GHz)
- Socket NA (integrated CPU)
- Memory Type DDR3
- Memory Speed 1066 MHz
- Slots 2 x 204-pin SO-DIMM
- Capacity up to 4GB
- DirectX DirectX 11
- OpenGL 4.1
- Ethernet 10/100/1000 Mbps
- WiFi 802.11n/g/b + Bluetooth 3.0
- Audio: Analog Stereo Output
- Digital 8-ch via HDMI
- Hard Drive 2.5" drive bay
- SATA 3.0 Gb/s compatible
- Optical Drive na
- Memory Card Reader 6-in-1 (MMC/SD/SDHC/MS/MS Pro/xD)
- DVI 1
- HDMI 1
- DisplayPort 0
- SATA 1 (SATA 3.0 Gb/s)
- eSATA na
- IDE na
- PS2 na
- Serial Port na
- USB Ports 2 USB 3.0 (on back panel)
- 4 USB 2.0 (2 on back panel 1 on top 1 front)
- Cooler Smartfan
- Form Factor mini-PC
- OS Compatibility: Windows User installed (Windows 7 ready)
Package Contents
- 1 x ZOTAC ZBOX ID84
- 1 x MCE compatible remote
- 2 x CR2032 batteries (for remote)
- 1 x USB IR receiver
- 1 x WiFi antenna
- 1 x VESA mount
- 1 x AC adapter
- 1 x Power cord
- 1 x Warranty card
- 1 x User manual
- 1 x Driver DVD
- ZOTAC ZBOX ID84 - mini PC - Atom D2550 1.86 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Atom D2550 / 1.86 GHz (Dual-Core)
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 0 GB (installed) / 4 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- 6 in 1
- Graphics Controller
- NVIDIA GeForce GT 520M
- Video Memory
- 512 MB
- Audio Output
- 7.1 channel surround - integrated
- Networking
- GigE, 802.11b/g/n, Bluetooth 3.0
- OS Provided
- No operating system
- Software Included
- Drivers & Utilities
- 18.8 cm x 18.8 cm x 4.4 cm
- PC barebone
- Product Form Factor
- Mini PC
Processor / Chipset
- CPU
- Intel Atom D2550
- Clock Speed
- 1.86 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel NM10 Express
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- 0 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Card Reader
- 6 in 1 card reader
- Supported Flash Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Memory
- 512 MB
- Video Interfaces
- DVI, HDMI
Audio Output
- Integrated
- Sound Output Mode
- Integrated
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin
- 1 x DVI , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 2 x USB 3.0
- Included Accessories
- Remote control, vertical stand, wireless antenna, VESA mounting kit, USB IR receiver
- VESA Mounting Interface
- Power adapter
Operating System / Software
- OS Provided
- Software
- 18.8 cm
- 18.8 cm
- 4.4 cm
Zotac Z-Box Nano Atom D2550 GT520M DDR3 Mini-PC
