Zotac Z-Box Dual Core Intel Atom D525 1.8GHz NVIDIA ION Mini PC
Quicklinx: 7FF4WS00 Mfr#: ZBOX-ID41-B
Enjoy eco-friendly computing with superior energy-efficiency and performance with the Zotac ZBOX ID41 mini-PC powered by the class-leading Next-Generation NVIDIA ION and Intel Atom architectures. Next-Generation NVIDIA ION graphics deliver unrivaled levels of performance and high definition video decode capabilities to the Zotac ZBOX ID41 mini-PC with NVIDIA CUDA, PureVideo HD and HDMI 1.3a technologies for eco-friendly computing with premium audio and video capabilities.
High performance eco-friendly computing is only two thumb screws away with the Zotac ZBOX ID41 mini-PC thanks to a user friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and 2 204-pin DDR3-800 SODIMM slot enables users to customize the internals of the ZOTAC ZBOX ID41 to their own needs while USB 3.0 and USB 2.0 ports, a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) and eSATA port provide greater external expansion capabilities for perfect eco-friendly computing.
  • NVIDIA PureVideo HD technology
  • NVIDIA CUDA technology
  • Adobe Flash Player 10.1 acceleration
  • Microsoft DirectX 10.1 compatible 2 Year Warranty
  • Model; Model ZOTAC ZBOX ID41
  • Chipset: Manufacturer Intel®, Chipset NM10 Express, GPU Next-Generation NVIDIA ION™ w/512MB DDR3
  • CPU Compatibility: Name Intel® Atom™ D525 (dual-core) (1.8 GHz), Socket NA (integrated CPU), Front-side bus 800 MHz
  • Memory: Memory Type DDR3, Memory Speed 800 MHz, Slots 2 x 204-pin SODIMM, Capacity up to 4GB
  • 3D API: DirectX DirectX 10.1, OpenGL OpenGL 3.2
  • Networking: Ethernet 10/100/1000 Mbps, WiFi 802.11n/g/b (300Mbps)
  • Audio: Analog Stereo Output Digital 8-ch via HDMI, S/PDIF
  • Storage: Hard Drive Support 2.5-inch SATA 3.0 Gb/s HDD/SSD, Optical Drive NA, Memory Card Reader 6-in-1 (MMC/SD/SDHC/MS/MS Pro/xD)
  • Ports: DVI 1 (Dual-link), HDMI 1 (HDCP w/8-channel digital audio), VGA N/A, SATA 1 (SATA 3.0 Gbps), eSATA 1, IDE N/A, PS/2 N/A, Serial Port N/A, USB Ports 2 USB 3.0 (on back panel) 4 USB 2.0 (2 back panel, 1 front panel, 1 top panel), Firewire N/A
  • OS Compatibility: Windows User installed (Windows XP, Vista, 7 and Linux ready)
  • General: SLI Supported No, Maximum Resolution N/A
  • Other: Wake-On Support, Overclocking features
  • Warranty: 2 Years
