Experience superior DVD video playback at resolutions up to 1080p with the Zotac Zbox DVD ID31 powered by Next-Generation NVIDIA ION technology with 512MB of DDR3 video memory. NVIDIA PureVideo HD technology enables the Zotac Zbox DVD ID31 to enhance DVD video playback using the integrated slot-load DVD drive and advanced video processing algorithms to deliver near high-definition video quality from standard definition DVDs. An Intel Atom D525 joins the Next-Generation NVIDIA ION graphics processor to form an energy-efficient duo able to deliver a premium computing experience with rich audio, video and web capabilities with the Zotac Zbox DVD ID31. Class-leading expansion capabilities equip the Zotac Zbox DVD ID31 with room to accommodate a 2.5-inch SATA hard drive, two DDR2 SO-DIMM slots and one mini-PCI Express slot in addition to the standard one USB 3.0, USB 2.0 port, combo eSATA 3.0 Gb/s and USB 2.0 port, DVI, HDMI, S/PDIF optical outputs, 6-in-1 memory card reader and 802.11n (300Mb/s) WiFi.
- NVIDIA PureVideo HD technology
- NVIDIA CUDA technology
- Adobe Flash Player 10.1 acceleration
- Microsoft DirectX 10.1 compatible
- 2 Years Warranty
- NVIDIA ION GPU (w/512MB DDR3 memory)
- Intel Atom D525 CPU (1.8 GHz, dual-core)
- Intel NM10 Express chipset
- Internal Expansion: 1 x 2.5-inch SATA 3.0 Gb/s hard drive
- 9.5mm height HDD compatible
- 2 x 200-pin DDR2-800 SO-DIMM (Up to 4GB memory)
- 1 Mini-PCI Express slot
- Display Outputs: HDMI (1080p w/8-channel audio), Dual-link DVI-I, HDCP compliant, VGA (with DVI-to-VGA adapter), NVIDIA nView multi-display technology
- Front Panel: 8x DVD±R/RW / 24x CD±R/RW read/write, 6-in-1 Memory card reader (MMC/SD/SDHC/MS/MS Pro/xD), 1 x USB 2.0 port, 1 x USB 3.0 port,1 x Headphone/audio output jack, 1 x Microphone/line input jack, Power button
- Rear Panel: 1 x USB 3.0 port, 10/100/1000 Ethernet (RJ45), Combo eSATA / USB 2.0 port, Digital S/PDIF output, Kensington lock connector, Power connector
- Features: NVIDIA PureVideo HD technology, NVIDIA CUDA technology, Adobe Flash Player 10.1 acceleration, Microsoft DirectX 10.1 compatible, Microsoft DirectCompute ready, OpenGL 3.2 compatible, OpenCL compatible, Integrated 802.11n WiFi (300Mbps)
- ZOTAC Atom TFT
- Built-in Devices
- Stereo speakers
- Processor
- Atom
RAM
- Technology
- DDR3 SDRAM
Card Reader
- Supported Flash Memory Cards
- SD Memory Card, MultiMediaCard
Audio
- Audio Output
- Sound card
- High Definition Audio
- Audio Input
- Microphone
Input Device(s)
- Keyboard, touchpad
- Networking
- Network adapter
- Data Link Protocol
- Ethernet, Fast Ethernet
- Power Device
- External
- Voltage Required
- AC 120/230 V
