Zotac Z-Box AMD M1 Fusion E450 DDR3 WiFi Media PC
Quicklinx: 80DNWS00 Mfr#: ZBOX-AD04-B
  • Bluetooth 3.0
  • IEEE 802.11n
Raise your performance expectations for energy-efficient computing with the digital media friendly ZOTAC ZBOX AD04 mini-PC powered by the AMD E-450 APU platform. Paired with AMD Radeon discrete-class graphics, the ZOTAC ZBOX AD04 delivers the perfect synergy of GPU and CPU performance for a rich multimedia computing experience with flawless high-definition video playback capabilities and ultra-fast responsiveness for regular day-to-day computing tasks.
High performance energy-efficient computing is only two thumbscrews away with the ZOTAC ZBOX AD04 mini-PC thanks to a user-friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and 2 204-pin DDR3-1333 SO-DIMM slots enables users to customize the internals of the ZOTAC ZBOX AD04 to their own needs while USB 3.0 and USB 2.0 ports and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) provide greater external expansion capabilities for perfect energy-efficient computing.
ZOTAC ZBOX AD04 - mini PC - E-450 1.65 GHz - 0 GB - no HDD
PC barebone - mini PC
1 x AMD E-450 1.65 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
0 GB (installed) / 8 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
6 in 1
Graphics Controller
AMD Radeon HD 6320
Audio Output
7.1 channel surround - integrated
GigE, 802.11b/g/n, Bluetooth 3.0
OS Provided
No operating system
Software Included
Drivers & Utilities
18.8 cm x 18.8 cm x 4.4 cm
PC barebone
Product Form Factor
Mini PC
Processor / Chipset
CPU
AMD E-450
Clock Speed
1.65 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
0 GB / 8 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6320
Video Interfaces
DVI, HDMI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Integrated
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 (1 front, 2 rear) , 1 x headphones , 1 x microphone , 1 x TOSLINK , 2 x USB 3.0
Remote control, vertical stand, wireless antenna, VESA mounting kit, USB IR receiver
HDMI-DVI adapter
Power adapter
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
18.8 cm
18.8 cm
4.4 cm
