Zotac GeForce GTX 780 3GB GDDR5 PCI-Express 3.0x16 HDMI OC
Quicklinx: 9KP8WS00 Mfr#: ZT-70206-10P
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Experience PC gaming like never before with surreal visuals and world-class performance with the ZOTAC GeForce GTX 780 OC. The ZOTAC GeForce GTX 780 OC ushers in the next generation of PC gaming with unmatched visual realism and performance for the most demanding gamers and enthusiasts.
NVIDIA 3D Vision Surround technology enables the ZOTAC GeForce GTX 780 OC to drive up to three displays for high-quality triple display gaming with immersive stereoscopic 3D effects. NVIDIA 3-way SLI readiness lets the most demanding enthusiast gamers combine up to three ZOTAC GeForce GTX 780 OC graphics cards for up to a 280-percent performance boost.
ZOTAC GeForce GTX 780 OC - graphics card - GF GTX 780 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 780
3 GB GDDR5
Core Clock
941 MHz
Boost Clock
993 MHz
CUDA Cores
2304
Effective Memory Clock
6.008 GHz
Memory Interface
384-bit
Max Resolution
2560 x 1600
HDMI , DisplayPort , VGA - with adapter , 2 x DVI-D (dual link)
API Supported
DirectX 11.2, OpenGL 4.4
26.67 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
941 MHz
Boost Clock
993 MHz
CUDA Cores
2304
Max Resolution
2560 x 1600
API Supported
Dual Slot Fan Cooler, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, 3D Vision Surround, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
384-bit
Microsoft Windows 7, Windows 8
Required Power Supply
700 W
255 Watt
Dual 6-pin PCIe to 8-pin power adapter, Dual 4-pin to 6-pin PCIe adapters
1 x DVI-VGA adapter
Software Included
Drivers & Utilities
RoHS
26.67 cm
11.115 cm
